Philips 42PF9630A 42 in. Plasma Television
Problem for Philips 42PF9630A 42 in. Plasma Television
I have a Philips plasma 42 with black lines across the screen
By iamjohnnyd on Aug 26, 2009
I have a Philips plasma 42'' TV (Model#42PF9630A/37) which worked perfectly fine when I turned it off one night and when I turned it on the next day, the picture was all dostorted with hundreds of black lines going across the screen and bizarre groupings of what looks like confetti in all different colors swirling around in various ever changing shapes all over the screen. I've tried unplugging the set, turning off the ambient lighting, and a host menu options to reset or adjust the picture and such. All with no change to the problem. I'm sorry the description is so vague, but it is very difficult to describe. Please advise.
Comments:
Aug 27, 2009
- Updated the firmware which unfortunately didn't correct the problem. Was wondering if forwarding a picture of the screen would be helpful? Are replacement boards (if determined to be bad) readily available from Philips or is there a better source?
Best Solution
posted on Aug 26, 2009
Helpful)
electroguy
Rank: Guru
Rating: 87%, 111 votes
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Philips 42PF9630A 42 in.
Questions and Unsolved Problems for Philips 42PF9630A 42 in.
Do you recommend Philips 42PF9630A 42 in. Plasma Television?
Answer
Answer
phillips plasma 42'' comes on but will not exit menu
Answer
Picture will not turn on. The sound goes on and off and then a red light starts flashing. flashing... (More)
Answer
The picture just goes off but the sound is still on. If you turn it off for a few minutes it... (More)
Answer
42 inch philips plasma just turns itself off. when it eventually comes on again it switches itself... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , MD
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
