Question about Sanyo DP26746 26 in. LCD Television
Wide screen lcd hdtv
No picture has sound
  • 5 more comments
  • Anonymous Jan 02, 2008
    no picture
  • abbis_mom Aug 13, 2008
    At first, turning the unit on and off a few times would finally result in getting a picture. Then the picture stopped coming on at all. Sound still works fine, as does the remote. Only had the unti about 15 months when this started. BTW, this is the first and last Sanyo product I'll be owning.
  • Anonymous Oct 31, 2008
    just bought a new sanyo 26 in hdtv.
    have to turn it on and off from 2-7 times before picture comes on, sound is ok, on screen "no signal" untill i turn it off and on a few times.
  • Anonymous Dec 02, 2008
    PICTURE BLACKS OUT WITH ONLY THIN LINE AT TOP OF SCREEN. TV IS ONLY ONE AND A HALF YEARS OLD. PURCHASED AT WALLMART, WISCONSIN RAPIDS. SOUND STILL WORKS. REMOTE STILL WORKS. VERY DISSAPOINTED! ALOT OF MONEY FOR ALOT OF NOTHING!! WILL CERTAINLY AVOID SANYO PRODUCTS FROM NOW ON.
  • Larrybarton1 Dec 02, 2008
    SCREEN BLACKS OUT WITH ONLY THIN LINE AT TOP OF SCREEN. SOUND AND REMOTE STILL WORK. ALSO PURCHASED AT WALLMART LESS THAN TWO YEARS AGO. PAID $ 598.00 ON 03/07/07. AFTER READING THAT ALOT OF OTHERS ARE HAVING THE SAME PROBLEM I HOPE THAT SANYO HAS AN EASY AND INEXPENSIVE FIX FOR WHAT HAS TURNED OUT TO BE A LEMON.
  • Ranfisher Dec 27, 2008
    I have the same issue. One day when the screen went black for a commercial, it never came back on. I have replaced the main board but it did not work. Would changing the LCD Lamp help?
    Thanks,
    Randy
  • Ranfisher May 11, 2010
    Why does your site show 1 solution by nikiwiki but when I click on it, there is no solution???? I replaced the main board and the LCD Controller board with no success. When I power on the TV I see the screen change from black to gray but then goes black again instead of showing images. Anyone know where we can email Sanyo instead of calling their 800 number??
LOTS of people have this SAME problem
Posted on Jun 04, 2008
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
The picture seems too big for the sreen eg sky sports channel 405 i car nt see the information on the right of the screen
Can you use the 'WIDE' button on the remote to change the aspect ratio? It sounds like it is in ZOOM mode.
Dec 30, 2010 | Vizio L32 32 in. LCD HDTV
I just bought the tv today, it's all set up & working but the picture does not extend over the whole screen - each side has about a 6 inch blank space. How can I adjust that?
take the remote, press menu scroll through till you get to picture.... (zoom 1, zoom 2, panaramic, normal, auto and wide screen)..... please note some HD channel are in wide screen...
Nov 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Feb 24, 2010 | Samsung LN55B650 55 in. LCD HDTV
When on wide mode there the full screen is not
This is very normal not all channels are HD some programs are taped like that will not fill your screen like dvd movies are.
Nov 18, 2009 | Insignia 42" LCD Flat-Panel HDTV
The picture is too big for the screen
sounds like your either in "cinema mode" or "zoom mode". does it do it on all inputs
Jul 06, 2009 | LG 37LG50 37 in. LCD HDTV
In the mode where i choose either wide or
The feature you're trying to use is grayed out when it's not available. Check your remote for a "zoom" or "picture size" button. Press the button a few times and you should find a setting which brings the whole picture back onto the screen. It sounds like you are zoomed in too far right now, so captions at the bottom are being cut off.
Mar 19, 2009 | Vizio L32 32 in. LCD HDTV
Sound No Picture Sanyo LCD WIDE Screen HDTV
Hello heck75,
I wrote this for another post but it applies here also:
This sounds like your inverter or back-light has gone out. What you can do to test this is to turn the TV on and then turn off all of the lights until the room is dark. Then shine a flashlight at an angle on the screen and see if you can see a picture. If you can the back-light and or inverter has malfunctioned. If this is the case, then I would suggest that you have a qualified TV technician fix this problem, but first ask for a estimate because the inverters and back-lights are sometimes part of the screen and is it is you might as well buy a new TV.
If the inverter is a separate board, If you have a background in electronics you might be able to repair the board, however if you do not have a background in electronics, again I would suggest getting a qualified TV technician to work on your set.
I hope this helps,
Thank you,
Shuttle83
Electron-Age Technologies LLC
www.electron-age-technologies-llc.com
Oct 31, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP26746 26 in. LCD Television Logo
112 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
