Question about Samsung HLR5067WX 50" Rear Projection HDTV
Whirring noise at stasrt up have a pretty loud whirring noise then it calms down quite a bit but you can still hear it...cooling fan?? any way to lube it or>>>>???????
  • 1 more comment
  • azmxers Dec 20, 2007
    whinning noise on 50 inch samsung dlp tv
  • Anonymous Jan 25, 2008
    Whistling sound is continuous
  • quickdraw2 Feb 04, 2008
    We have the exact same noise problem. I don't think its the cooling fan because when set is turned off the noise stops and I believe the cooling fan is still running until unit cools off. Then the fan seems to shut off. The whirring noise sometimes is unbearable and we shut off tv.
    President:
  • 4,402 Answers
This is for hls and hlt but i think this is what your set is doing
http://fixyourdlp.com/blog/?p=258
Posted on Dec 05, 2007
Cooling fan is loud on initial start up and calms down after a couple hours use. Can I change out the fan and what is the part number on the HL-P4663W?
This tv internal curcuitries and manchanical design have a colors wheel in it.The tv have loud squiling noises,motor noises,black&white or colors flickers and fating.All the effect of the tv colors wheel is dying and spinning off of it motor axis.Cooling fan make noises for a couple hours,calm down,no way.The fan would have stop functioning,way before that.
Jul 21, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Loud whirring noise in my Samsung dlp rear projection tv. HL-M507wx/xxa. Is this the color wheel or cooling fan? can I replace myself? I changed the lamp and that was pretty easy.
fan is easy to replace, color wheel will require a technician.you can remove lower back cover and see the fan but i'm guessing it's the color wheel.
Nov 04, 2009 | Televison & Video
Seems to be a noisy fan on mb4210 combo
Could very well be the fan. The motors can cause interference. There may be a solution to get rid of the noise. Some copper shielding tape may help. You could rule out it being a microphonic preamp tube by turning the amp on as normal and tapping the tubes with something non-conductive. If you hear the tapping noise coming thru the speakers while doing this to a particular tube, replace it. With power tubes, the tops of them turn white on the top when they become microphonic, along with plenty background noise.
Apr 18, 2009 | Marshall Music
Loud whirring noise from home theater receiver
Sounds like a cooling fan is worn out. If the warranty has expired, remove the cover and there should be a cooling fan. Remove the fan. Try cleaning it out with a can of compressed air. If this does not work take the fan to best buy or circuit city and buy a replacement. I hopet his solves your problem!
Jan 09, 2009 | Samsung HT-TZ512T Theater System with...
Vaio PCG-R505EL - fan making noise
I too removed the fan from the housing and cleaned the fan shaft with a Qtip. Then I cleaned the magnets.
THEN I used a really light bike chain lube called Prolink to lightly lube the magnets and the fan shaft.
The thinness of the lube ensures that it won't gum up the fan shaft and if the shaft does make contact with the housing it won't make quite so much noise.
Three days now and the difference from "grinding chrun" to whirring fan is noticeable.
Sep 09, 2008 | Computers & Internet
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
204 people viewed this question
Jerry Greenberg
Jerry Greenberg
