Question about Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator
Water always inside refrigerator sometimes ice forms
I have a '97 Roper side by side. It "Does Not" have a Ice Machine.. Every 2 weeks I have about 1/4 inch of water inside my meat storage container and both my bottom veggy drawers. Sometimes I'll find a tuperware bowl that was hidden in the back with Ice formed on its lid. Can you tell me why this is happening?.. Thanks a bunch.... =0) My freezer work fin but inside of my refrigerator there is always water inside and it doesn't get cold
  • 3 more comments
  • PuffyMan Feb 02, 2008
    I have a similar problem with a whirlpool model that's about 8 years old. Last week, there was water in the meat tray, the veggie trays and about half an inch of water at the bottom of the fridge. Also, when the water evaporates, it leaves a white powdery residue on everything. The freezer fan is working and all the air inlets are clear. The flap between the top and bottom also seem to work correctly.
  • KETGED Jul 31, 2008
    I have a '02-03 Kenmore 711821, top freezer. Every couple of days I find water
    inside the refrig on shelves. Also I'll find a tupperware bowls in the back with
    My freezer works fine and it seems cold in the refrigerator also. I could stick my finger up in the hole to the freezer and it does not seem to be blocked with frost. Once before, this hole was blocked and we had to have a new defroster heater installed(may be wrong term??), but at that time, things were not very cold in the refrigerator.
    What is this problem? Is there a non-functioning part or is there something we can do at home to fix?
  • Anonymous Oct 10, 2008
    why is there water inside my refrigerator
  • Anonymous Dec 18, 2008
    2002 71192100 WATER ON SHELVE AND IS ICY
  • Anonymous Mar 17, 2014
    I have a toshiba refrigerator with a automatic ice maker . The problem is that the ice is not forming and the water is remaining in the container
  • 100 Answers
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Posted on Dec 05, 2007
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Not making ice
There are several possibilities for this and the dual water control valve is one of the possible problems. Try pouring tap water into ice maker tray if no cubes are present. Allow it to freeze and if the cubes drop then the water control valve part Click Here=> 2188542-1 Then you have a possibility that the ice maker thermostat is at fault item number 27 in photo here=> 627985 Ice Maker Thermostat Sometimes the problem is located inside ice maker and buying new makes it more worth the cost than the cost of replacement parts. This is the Replacement and parts here=> 4317943 Complete Ice Maker
If you need additional help I can be found here or here=> Appliance 911, Thanks Sea Breeze
Oct 09, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice at bottom of freezer
Make sure defrost drain is completely cleared of ice and anything else obstructing it. Pouring hot water in it is correct, but make sure it is going all the way through to defrost pan under unit.
Oct 11, 2017 | Kenmore 52632 / 52634 / 52639 Side by Side...
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
taken from:
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My ice maker has just about quit working for no reason that I can find
Check to see if water is in ice cube forming tray. If No then probably a bad water inlet solenoid. Water line to fridge goes to inlet solenoid.
Feb 18, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Amana SBS Water and Ice maker issues
The water solenoid on the back of the refrigerator at the bottom is becoming clogged. There is only a very small hole in the diaphram of the valve. I suspect you have very hard water, or at least a fair amount of sediment in the water.
This valve will most likely need to be replaced by a qualified technician.
They sometimes can be cleaned, but it doesn't always work.
Jun 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Ice maker is not functioning
sounds like a frozen fill tube, easy to check pull out refrig and you see plstic tub running into top of freezer section from behind, sometimes theres a connector fitting half way up the tube, if not you have to cut tubing and install a coupling to repair cut(available at any harware store)after cutiin tube try blowin throughin to freezer, if you cant its frozen,un freezing somtimes challange, sometimes able to blow straight though the ice other timesi se hair dryer (from iside freezer where fills the ice maker itself. best way ive found is using my steam machine i bought from one of the infomercial.good luck!!!
Jan 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Jul 12, 2007 | Roper RT14DKX Top Freezer Refrigerator
Roper RS22AQXMQ00
When you try to get ice does it make any sounds (clanks, whirring, grinding,etc.) like something is happening inside or is it just quiet? If quiet, see if you can look up inside the door switch area with a flashlight and press the button with your finger instead of the lip of a glass. Post more info when you have it and we'll go from there.
Dec 11, 2006 | Roper RS22AQXKQ Side by Side Refrigerator
Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator Logo
505 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
