ProScan wont turn on
I have a proscan model # ps52690 that wont turn on and the green light flashes 3 times and thats it
  • 4,402 Answers
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Posted on Dec 05, 2007
Tv will not stay on Proscan PS52690
power supply probably needs to be rebuilt, vertical IC some filters,probably a couple of transistors. best to have an experienced tech do it for you.
Aug 30, 2009 | Proscan PS52690 52" Rear Projection...
Splitting a RCA Proscan 60 in 2
If there are plastic plugs on the sides of the tv (4) then you can take them out and expose a screw that if taken out will allow for this, otherwise you will have to get creative. good luck
Aug 29, 2009 | Proscan PS52690 52" Rear Projection...
Green Screen
put a fan behind it, if it works then its heat related if not then you probably need a new main board.
On and off switch won't respond manually or with remote.
Sounds like you have high voltage, I would have to guess the vertical IC has failed. its in the high voltage board and should be done by a qualified tech.
Jul 29, 2009 | Proscan PS52690 52" Rear Projection...
it sounds like the main power supply. unfortunately spare parts are no longer available for this model
Feb 21, 2009 | Proscan PS52690 52" Rear Projection...
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
Service manual for Proscan PS52690
I believe your model is a PTK188 can you look for the chassis number off the tag on the back, and I may be able to help you locate a manual, but the older RCA / Proscan / GE need the chassis number
Jun 14, 2008 | Televison & Video
Proscan PS52690 52inch
Make sure antenne is properly set. Toggle to A or B
Dec 30, 2007 | Proscan PS52690 52" Rear Projection...
Televison & Video Logo
268 people viewed this question
Top Televison & Video Experts
