Question about ASUS P5N-E SLI Motherboard
New system build, shuts off after 10 seconds
After pushing the power button, the computer turns on to the bios splash screen then shuts off after about 10 seconds
    Problem Solver:
  • 9 Answers
If you have had this problem sence the system was built and your power supply is less then 400 Watts. You will need a 400 Watt power supply or higher. Check the specs for our motherboard.
Posted on Dec 05, 2007
My acer aspire 1 725 wont load due to errorcode 0x00000f and cant get into bios to change boot options how do i fix this problem
Shut down your computer completely. Once it has been turned off, press the power button to the "On" position to restart the system. Within the first 10 seconds, press down and hold the F2 button for about three seconds and then release it. Within five to 10 seconds after pressing and holding this button, you should see the BIOS setup screen on the monitor.
Dec 30, 2013 | Acer Computers & Internet
Asus r503u bios
Shut down your Asus laptop. Click "Start" then click the "Shut down" button. Power your computer back on. Wait for the ASUS splash screen. Press the "ALT" and "F2" keys on your keyboard as soon as you see the ASUS splash screen. Your computer will enter the BIOS.
Feb 14, 2013 | ASUS R503U-RH21, AMD E2-1800, Laptop, 4GB,...
Need to access the menu
Know what the ->enter BIOS Setup key is?
It's on the bottom of the computer manufacturer logo screen.
Got it?
Now press the CTRL and ALT and DELete keys at the same time.
Restarts the computer.
JUST AS SOON AS IT STARTS, start tapping on the enter BIOS Setup key.
Tap in 2 seconds intervals.
If you hear beeps ignore it. These are Stuck Key Error Code beeps, and it is you that is making them.
Still No?
Turn the computer off by holding the Power On button in, for 10 seconds.
WAIT 20 seconds, then press the Power On button.
AS SOON AS YOU PRESS the Power On button, start tapping on the enter BIOS Setup key. The rest is above.
Regards,
joecoolsvette
[The time period to enter BIOS Setup goes by F-A-S-T!
As soon as you see the computer manufacturer 'splash screen', (Logo screen), it may be TOO late. The above method makes sure you get in BIOS Setup ]
Nov 21, 2012 | Computers & Internet
Is there a way to change windows xp bios settings after boot up, particularily using the command line?
My knowledge of using the command line is equal to my knowledge about astrophysics. Zero.
You can change BIOS settings in the BIOS Setup utility. After the computer manufacturer's splash screen, (Logo screen), and at the bottom of the screen, are shown the key/s to press to enter BIOS Setup.
Goes by real F-A-S-T. Try to write it down. Let Windows load all the way, then restart the computer.
As SOON as you see the manufacturer's splash screen, start tapping on the key/s to enter BIOS Setup. If you miss this window of opportunity, let Windows load all the way. Turn the computer off normally. (Wait at least 20 seconds) This time as Soon as you press the Power On button, start tapping on the appropriate key/s. (In 2 second intervals) You don't get as far as the splash screen? Then unplug the computer from power. Observe Anti-Static Precautions. Remove the CMOS battery, (CR2032), for 1 minute. Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. Let go of the Power On button. Do this procedure two more times. Install the CMOS battery. Plug into power. WAIT 1 minute, turn the computer on. This procedure will set the BIOS Settings back to the factory default settings, and clear CMOS Error Codes. Post back as to your findings.
Sep 14, 2011 | Computers & Internet
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
CRC Problem
Chances are since the system CRC1'd it has a very old BIOS revision. From version 1.10 on, the CRC issue has been fixed. So, get the latest BIOS from IBM, T21 BIOS: ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/spsdkz34.exe and flash the BIOS. Reboot the system and verify the updated BIOS. Now power down the system, desolder the known good EEPROM and resolder the CRC1 EEPROM. Boot the machine and hit ESC when the splash screen comes up and watch the post screen. The new BIOS should have recalculated the EEPROM checksum and written the changes to it. You'll know if it worked because the CRC1 error will be gone.
Jan 03, 2009 | IBM (09N5424) Motherboard
Acerpower SV PC will Not turn off
More information would help to resolve this issue.
Are you shutting down by selecting Start and shutdown or have you tried pushing the power button on push (not holding the power button)?
Try this:
Press and hold the power button in solidly for about 10 seconds. If it shuts down before you get to 10 just let off the power button. This should work, but may not solve the problem.
If you reboot it and still can not shut down from Windows, hold power button until it shuts down, unplug the power cord and disconnect everything from the computer other than the keyboard, mouse and monitor. With the power plug still unplugged, hold the power button in for about 15 seconds (this resets the power supply and can clear a corrupt BIOS).
Reconnect power and after booting, see if you can shut down from Windows.
If still no go, click Start, Programs, Accessories, System tools and select System Restore.
Follow the prompts and select a bold date back to a time before you had problems shutting down. That should do the trick.
Let me know if you get it fixed or if you need more advice.
Honest1abe
Jan 02, 2009 | AcerPower SV PC Desktop
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Oct 11, 2008 | Dell XPS 200 PC Desktop
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
ASUS P5N-E SLI Motherboard Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
