Iomega 33089 250 GB Hard Drive
Problem for Iomega 33089 250 GB Hard Drive
Vista stops recognizing external hard drive
By asullivan24 on Aug 26, 2009
I have an iomega external hard drive connected via USB that has worked great up until two days ago. When I first turn on my laptop, it is listed in Computer and in Disk Management. However, if the cable gets jiggled, the computer stops recognizing it and won't recognize it again (in Computer or Disk Management) unless I restart the laptop. This is true for all of the USB ports. All other USB devices work fine. All the normal lights come on the hard drive and I have tried a different USB cable with the same results. My OS is Vista. Any help would be appreciated.
Best Solution
posted on Aug 26, 2009
Very Helpful)
jgrave
Rank: Guide
Rating: 67%, 4 votes
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
darkstar-123
Rank: Wiz
Rating: 82%, 32 votes
seems you have tride there is maybe only one suggeston
you may have dry joints/ inside your external via- your usb which needs soldering you shold get someone to check for you hope this helps
Was this helpful?
Yes
No
Popular Solutions for Iomega 33089 250 GB Hard Drive
Questions and Unsolved Problems for Iomega 33089 250 GB Hard Drive
Do you recommend Iomega 33089 250 GB Hard Drive?
Answer
Answer
can't add or delete files / folders on my iomega 250gb on my mac pro
Answer
i am running a mac G4 OS 10.4.11, i was copying files to my external iomega 250 GB drive when finder... (More)
Answer
but is continues to appear on my mac... i just can't get it to recognize the external device on my... (More)
Answer
I have been using my Iomega External Hard Drive to back up my files on my PC (HDD Model). To date,... (More)
Answer
need to reformat external harddrive to NTFS format in order to image my system with windows vista... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Iomega 33089 250 GB Hard Drive:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14882
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
