Question about Amana ATB1935HR Top Freezer Refrigerator
Buzzing sound My refrigerator started making a buzzing sound, lasting about 10 seconds, and repeating about every 2 minutes. I came home today to discover neither the fridge or freezer is working(light is on but neither are cold). Can you tell me what this is and will it be expensive to repair?
  • 1 more comment
  • abitibi Feb 13, 2008
    Buzzing sound started a few weeks ago for 10 seconds every 3 minutes. The fridge was working but now it does not hold the cold anymore either for the fridge or freezer.
  • Anonymous Jun 04, 2008
    My compressor humms for 3 seconds then stops for 30 seconds. Then repeats over and over. What is this "Hard start capacitor" that Hotuna is refering to? I'd like to try that. Thanks in Advance
  • Anonymous Mar 23, 2014
    My miele refrigerator makes a buzzing sound when I open the door. The sound lasts only for 1-2 seconds and the problem is inconsistent. We have the Miele K1911
  • 288 Answers
The buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
Posted on Dec 05, 2007
Refrigerator makes a buzzing sound for 10 seconds clicks and stops making the sound. This happens every minute or so
I believe that buzzing sound is coming from the start relay and the click is the overload clicking because the compressor is trying to start but cannot because the start relay is defective, You may have a run or start capacitor bad also, Thanks Sea Breeze
Model Number?
Nov 17, 2012 | Refrigerators
Freezer thawed out in the night, makes a buzzing sound every minute or so and lasts about 10 seconds.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Feb 14, 2011 | Amana Refrigerators
Admiral refridgerator model lsd2615hez is making a buzzing sound every 2 minutes. The buzzing sound lasts 20 seconds and everything in the freezer is melting. What could be causing this?
what you are hearing is the compresor trying to start . and can not so the over load is shutting down . and when it cools it will try again .. you need to replace the starting device on the compressor .cost about 80.00 parts .. most models . some are more. and the melting is caused by no comp runing .. this is a very common problem .. hope this helps mm feed back pls .
Feb 01, 2011 | Admiral 26 cu. ft. Side-By-Side...
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
It is making a buzzing sound
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!! " - mibarra20605
Apr 12, 2010 | Amana DRS2660B Side by Side Refrigerator
Fridge has a buzzing sound
Sounds of the start relay is struggling to get the compressor started. In most cases the start components will need replaced to prevent further damage to compressor and loss of food storage. In these cases I always test the compressor windings to insure the compressor winding are not breaking down. I will not be able to tell you the parts you will need but it is a sure deal, work will need to be done in this area. I will need your model number to assist in parts. I will give you a helpful link on a compressor windings test. I reccomend that someone do the work soon, Thanks, Sea Breeze
Feb 23, 2010 | Maytag Refrigerators
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Buzzing sound for about 2 months
Compressor was replaced (also see additional comments made).
Mar 20, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Amana ATB1935HR Top Freezer Refrigerator Logo
377 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
