Question about MSI NX6600GT- VTD128 GEFORCE 6600GT AGP8X 128MB DDR3 DVI+DB15+TV- OUT+VIVO RETAIL Graphic Card
Is there any way to fix a cooler
Hello!A fan from my nx6600gt video card broke and fall off. Is their any way I can buy new fan and stick it to the cooler?
  • 1,601 Answers
MSI VGA Products are warranted for 3 year limited warranty (Two (2) years Parts & Labor, and the third Year Parts ONLY, shipping and handling fee will be required).
I would send it back
Posted on Dec 05, 2007
System does not work. What does the E0 message mean on the base?
Hello ,
Try swapping the ram in the slots, or testing one stick at a time.
If the above solution didn't work for you check below
"E0" error to be fixed by swapping the DVI cable's position from the mobo port to the graphics card's port, Make sure your cpu cooler fan is connected to the cpu fan header. If non of these sulotions worked for you, make sure your sticks are seated all the way back. Also try using different sticks, if you have any lying around. Or borrow some from your friends.
Hope one of these work for you
May 02, 2016 | Uniden Cordless Phone
Plese give me nx6600gt dirver problem
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
You need to install the latest drivers from the Nvidia website.
It is all explained in my published guide entitled How to install Graphics Drivers, Nvidia and AMD Radeon!!!
The section on Nvidia Graphics Cards pertains to you!
All the best and happy computing!
Mar 01, 2011 | MSI NX6600GT- VTD128 GEFORCE 6600GT AGP8X...
You can find replacement fans in a number of places such as, and many others. The important thing to keep in mind here is that replacing the cooler is sometimes difficult, and if you dont have experience in this area, it may not fix your issue.
That being said, an aftermarket cooler would be the easiest to find other than looking for an old card (exactly like yours) on ebay.
If you did find one, and it should be inexpensive... you could just use it to replace your current card.
I, like you often wish I could just replace my fan on my video card, but the truth is, those are practically disposable. See this auction for a similar replacement at a mere 4.00.
Remember, buying online can be tricky.. be sure you are aware of the dangers! I am in no way affiliated with ebay nor the auction which is listed above. That is the result of a quick search to help you on your way!
Hope it helps!!!
Feb 23, 2011 | MSI RX1300PRO-TD256E RADEON X1300 PRO,...
My cooling Fan in my ATI RADEON X600 PCI Express Graphic Card his dead. Would like to know if their is somewhere I could buy one. Thank You
Here's a few,
Few more,
One more time,
Some information on installing a GPU cooler.
(Also check out the other videos to the right)
[ GPU stands for Graphics Processing Unit. The ATI Radeon X600 series uses an ATI Radeon R300 GPU, ]
If you are replacing using more than just a Fan, such as using a GPU cooler that also has a Heatsink attached, do not forget to Thoroughly clean the top of the GPU's case, and Properly apply fresh, new Thermal Paste.
If you have Any questions regarding installing an aftermarket fan, or GPU cooler, please post in a Comment.
We'll step by step through it by posting back, and forth.
Nov 16, 2010 | ATI RADEON X600 Pro, (128 MB) PCI Express...
How to fixs my memort stick pro duo it keeps
try to insert in other memory reader, if still not work better buy a new one.
Apr 05, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Have you tried using compressed air (tech duster) to clean out cooler fan blades and heat sink?
Oct 27, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Video card shut down
you probably need a higher watt power supply in your case. Most stock ones are only about 350 watt. you'l need like a 450 watt or better with that power hungry card.
Sep 17, 2009 | Palit Microsystems GeForce 9600GT, DDR3...
Ati Radeon hd 4850 overheating
Hello b ciprian,
The trick to keeping a CPU or Graphics Card from overheating is to be able to supply the largest amount of cool air coming in. I have gone as far as using a Dremel to router holes in the side of a PC case to add more fans.
Typically I like to have (3)three 80mm or 120mm intake fans in the side panel, (2) 80mm or 120mm fans as exhaust fans. I even remove the front panel to see how many and what size of Intake fans I can put there.
With almost every graphics card that I have used or installed, I have always added a 3rd party VGA cooler. Most of the factory VGA Coolers are mediocre at best. When ever I install a 3rd party VGA cooler, I always use Arctic Silver 5 Thermal Compound which is 99.9% Silver, which goes between the VGA Cooler Heatsink and the GPU(graphics processing unit).
You can also buy rather inexspensive heatsink kits(applied with thermal tape) that you can attach to the memory chips on the graphics card itself.
I also replace the factory thermal paste that is used for the CPU heatsink/fan with Arctic SIlver 5.
While I am at it, I buy a heatsink for the southbridge, and sometimes the northbridge, as well. Since this is a VERTICAL application, you really should consider using Thermal Tape or Thermal Adhesive. You can use Thermal Adhesive for the Northbridge and Southbridge Heatsinks ONLY. DO NOT use thermal adhesive on your CPU or VGA Cooler.
Here are some nice VGA memory heatsink kits from Newegg.Com or
Here is Arctic Silver 5 Thermal Compound:
Here is the link to the CPU heatsinks. Just find the one that is compatible to your motherboard.
Here is a HIGHLY RECOMMENDED item. This is the VGA cooler that is compatible with the HD 4850/70/90
And here is a link for a fairly universal VGA cooler. It costs less but I've had it on my card for one year now and love it. But your card runs A LOT hotter than mine so I would choose the one above.
Here is a link to case fans. You really shouldn't buy any fan that is over $8.
If you order fans for your case, they should come supplied with the 4-pin Molex adapter for the PSU. If not, your local PC repair shop or places such as RadioShack should have them.
I think I covered most of the bases. Hope all goes well for you.
Jul 12, 2009 | ATI RADEON HD 4850,, PCI Express Video...
RX9550SE-TD128 graphic problem
First try turning down the setting on the games. If that doesn't work try getting a better cooler for your video card, one that isn't passive. Like a zalman heatsink and fan with, video ram heatsinks.
Jan 22, 2009 | MSI RX9550SE-TD128 (128 MB) Graphic Card
Computers & Internet Logo
69 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
