After you have tried your several passwords you till can’t log in Windows system,you begin to cry,Does any body can help me!There aren’t anybody around you,you are waiting the computer work normally as there are much work need to do right away!
Don’t worry,you don’t have to reinstall the system.We’ll show you how to recover or reset your Windows password from a Windows Password Key CD.
This method works for all of the version of Windows-anything from Windows 2000 and later, basically. And yes, that includes Windows 7.
You’ll need:
1> a blank CD disk or USB flash drive.
2> a computer that can download from Internet .
3> a program that can
recover Windows password-Windows Password Key
If you have a Windows Password Key CD,you can go to recover your lost windows password,Or you need to see the follow part which shows how to create a Windows Password Key CD.
Step 1:Free Download
Windows Password Key 8.0 from the official website .
Step 2:Run the downloaded file to install.You can install it on any PC you have access to.
Step 3:Burn the program to a blank CD
It is easy to make a Windows Password Key CD,next,we’ll use the CD to reset Windows System.
1. Insert the newly created CD/USB to the locked computer.
2. Reboot the locked computer and press'F2'or'Delete'to enter your BIOS setup and then you will see the instruction as following.
3. Then you need to reboot the computher,Finally you will find your password has been removed.
Now you can regain access your Windows operating system and create a new administrator password. The best thing of using this method is that you shouldn't lose any data on your computer. Furthermore, If you can't find a computer which has a CD/DVD writer or the locked computer have no a CD-ROM, You can burn the ISO image file into a USB flash drive and use the USB flash drive to recover your Windows administrator password.
Try these three methods the next time you have
lost Windows administrator password, which you do not need to reinstall Windows system for getting back to Windows by removing lost or forgotten password.
hello,
many thanks for the fast reply.. no i have a black screen. and it says need windows set up cd rom. i'm so very worried that i could lost all my work. how can save with out this CD??
thank you
Linda
hello,
thank you
Linda
hello,
thank you
Linda
hello,
thank you
Linda
important how can i save all information before i restore..
many thanks linda
It depends on what the problem is, is it not booting at all? Is your windows initializing, or is your HDD bad?
