RCA MM52110 FUSE keeps blowing
I have a 2001 RCA Projection TV MM52110. We had a brown out and the fuse blow in tv. I replaced w/ 6am125v, same as was in tv. Every time I plug it in the fuse blows. Any help appreciated. Laid off can't afford a service call, would like to fix myself if possible.
Thanks
    President:
  • 4,402 Answers
Should be covered under your insurance might give them a call.
other wise i would check the bridge rectifier,
Posted on Dec 05, 2007
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Convergience not working, three color pictures and concaved top and bottom. Is there a module that I can replace?
Check the small brown fuse FL231 located just to the lower right of the flyback. There are 3 small brown fuses. The middle one is FL231. Most likely it is blown. The reason it blows is because of the lead free solder used on the new boards. If you turn the board over you will probably find cracked solder joints on the flyback terminals. Re-solder all of the flyback terminals and replace the fuse if it is blown. This fuse tells the TV that it is a rear frojection TV and not a standard CRT
Feb 08, 2010 | RCA HD52W59 HDTV Projection Television
My 52 in rca tv wont come on..the power button lights up and then shut off and then lights up again and shuts off..a couple of times when it did come on..the picture was wiggly..and when i play my...
Sounds like you have A blowed fuse on SSB board its the one you hookedup your xbox into fuses on right and left side of bottom tuner they small brown looking caps but are fuses. for replacement boards call UED for prices on new and rebuilt board 1-800-648-6657
Sep 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
RCA MM52110 tv
I had a repairman out to look at mine today. He said it was the high voltage protecter kicking off the TV as soon as you turned it on. $400 to $600. to repair.
I love this TV but guess I'll go shopping for another plasma. I have one Plasma TV in the bedroom 50" Samsung (top of the line) it doesn't have as good of a picture as my old RCA.
Jan 31, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA MM52110 FUSE REPLACEMENT
Check on the power supply box. Lower LH corner in back where the plug goes in. There is normally a small breaker switch on it.
Nov 30, 2007 | RCA MM52110 52" Rear Projection HDTV-Ready...
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
