Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Performa Washer
When the washer is filling, water is leaking out of it. I took the drain hose and put it out the side door of the garage, turned on the machine again and when the tub was a little more than a quarter full it discharged out the drain hose and began refilling. I then held up the drain hose to the hieght of the drain and it began leaking out of the machine again, I really can't tell where the water is leaking, but it seems somewhere near the top of the unit. water is found on floor from time to time. repair man blames my mom for adding to much soap to the load. he did no repair and took $120 for his 10min the same problem accurs when less saop is used as well. please help. no steps have been taken to repair. dont know where to start.
  • vitto Dec 05, 2007
    i will try that. i have just noticed today that when i started the cycle and it took water it kept taking and not stoping. and i noticed that the tub was very full. this does not happen when it takes on its mormal amount. could this be that same problem to your solution?
    Thank you
    President:
  • 878 Answers
Vitto, the fill hose for the tub is located up on top of the tub. Its a push in and I have on occasion see them come out or loose. You are going to have to pop the top to get a look at what is going on. First there will be 4 screws on the dispensor assy. each corner. Remove them and lift the cover. Next will be the door. Remove the hinge screws not from the door, but from the body. On the other side will be 2 spacers, remove them . Now lift the door up and off the washer. The front panel will now pull out and come off the 2 clips on the bottom. You will be able to see the bottom. Now there will be two angle clips on each side holding the top down. Remove the screws, clips and the top will lift up. Now you will be able to place the door back on with out screwing it back on and close it. Start a cycle and now you will be able to observe the top hoses and bottom pump and hoses. Identify where the leak is and put this deal behind you. This is an easy gig, just take your time. Catriver.
Posted on Dec 05, 2007
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Maytag Performa model mtw5740tq0: won't fill up with water
There is an exit hose behind your washer, it has to be maintained a particular height (approx 30inches from ground) before it goes into the standpipe in the wall. The gap in the pipe should not be a tight fit. Another thing that could have occurred is that one of the pipes underneath the washer has come loose; you just have to check these things out. But plug off the mains socket first!
Feb 10, 2010 | Maytag MTW5700TQ Top Load Washer
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Apr 28, 2008 | Maytag Performa PAV2200
Washer is not filling during rinse cycle.
Sounds like the water is being siphoned out by the drain hose. Check to see if the drain hose rises above the top of the tub.
Oct 29, 2007 | Maytag Performa PAV2200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
My washer just keeps trying to fill
check the height of the drain hose. if you aren't seeing a leak on the floor the drain hose might be below the height of the tub. the water always seeks the lowest level and if the hose is too low the water wwill run right out
Jul 27, 2007 | Maytag Performa PAV2200
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Maytag Neptune MAH5500B Front Load Washer Logo
320 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
