Question about Creative Labs ZEN SLEEK MP3 Player
Zen frozen on one screen even after I've restarted it.
My zen was working just fine last night, and this morning I went to listen to music and it started up as normal. It then froze on the Zen Sleek screen. I restarted it, and it happened again! I've tried restarting it a number of times and each time it restarts and freezes again at the Zen Sleek screen. Any help would be appreciated!
    President:
  • 4,402 Answers
Hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Posted on Dec 06, 2007
SOURCE:
Creative Zen M:vision - can't turn on/off, permanent blue light
Well, i didn't charge mine over night, was listening to it in the evening while doing some chores and all of a sudden it stopped playing, Blank screen and permanent Blue light. I tried to turn if off but it didn't respond so i left it. In the morning, it went off itself (guess the battery was low). So i connected to the computer and inserted the ZEN CD. As i was exploring the CD looking for a solution, then all of a sudden the screen came up with a note "Rebuilding..." after 5 secs it came on. With all my files intact! I hope this wud be helpful, You could give it a shot, after all there's nothing to loose!
Jan 15, 2010 | Creative Labs Zen Digital Media Player
Zen v plus
have you tryed rebooting at bottom lefthand corner with pin.
Aug 21, 2008 | Creative Labs Zen V MP3 Player
Zen
You may need to do a format on your Zen. It sounds like the file system is corrupt. For more detailed instructions on how to troubleshoot your Zen, click here
Aug 09, 2008 | Creative Labs Zen Digital Media Player
Creative zen v 2 gb formatting and screen problems
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Screen is white but music still plays
I have the same problem .. But i found a trick ...When you have a blank screen.
1 you must listen music else press play until you listen it
2. flip the switch on the side to lock position
3. press on buttom the next tune 1-2 seconds
4. you will have a black screen ( you listen the music again)
5. flip the switch on the side to normal position.
6 the screen appear ok now..
7. else repeat ( most time once is ok but sometimes 2 or 3 times)
connex_bern
Jan 31, 2008 | Creative Labs Zen Digital Media Player
Creative zen crash
The zen man need a full charge... if you have an ac adapter plug it in for at least eight hours. if you don't have an ac adapter plug it in via USB to a DESKTOP computer (not laptop) and try to use a differnt usb cord (creative doesn't always include a powerful enough cord to get the zen out of that low power state)
You don't loose all your music if you reset it.
refer to creative.com/support and look up info on your model to see if anyone else has your issue.
if it is totally busted your player is still under warranty
Jan 08, 2008 | Creative Labs Zen Digital Media Player
Creative Zen V Problem
remove the battery and the usb then plug back in. if that doesnt work hit the reset button (if this one has one)
Dec 06, 2007 | Creative Labs Zen V MP3 Player
Screen Frozen
This is not a Zen Vision:M. Likely a Zen Micro. The hard drive is bad and will need to be replaced.
Nov 06, 2007 | Creative Labs ZEN Vision:M Digital Media...
Frozen screen in shut down mode
ow!!! you got a virus! a doomboot virus and or flakes virus! do not open again your mp3! you have to remove your virus with twister series!
Oct 11, 2007 | Creative Labs ZEN V Plus MP3 Player
Not working at all, seemingly.
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Feb 21, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN SLEEK MP3 Player Logo
195 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
