Question about Medion md40298 Notebook
Medion MIM2120 laptop
I cant find the switch to enable my wireless connection. Where is it located?
  • Anonymous Feb 01, 2009
    I cant find the switch to activate wireless mode. can you tell me where it is?
  • Anonymous Mar 24, 2014
    where is the wireless switch located on the touchsmart 15
Press the blue button botton left of the keyboard that says Fn (function)
at the same time press F1 this will enable the laptops wireless connection, this should be shown by the light 2nd from the right
Posted on Dec 27, 2007
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
I have Medion 2310 notebook, and there is apparently a switch to enable wireless connection can use this switch to ON your wireless (wi-fi) adapter!
any problem with wireless ? tell me...! :)
Jan 02, 2010 | Medion md40298 Notebook
How do i switch on wireless on a medion laptop
There could be a switch located on the outside of the laptop. If not, go into Control Panel>Network and Internet>Network and Sharing Center>Change Adapter Settings, right click on your wireless device, and click "Enabled".
Dec 26, 2009 | Medion md40298 Notebook
I Can not find the wireless switch on the Akoya Medion notebook
Wireless is enabled by using the switch / button in front of the notebook. It is located in the right hand side, in front.
Refer to the user manual for the right picture in page number 22
Jul 22, 2009 | Computers & Internet
How do I fit wireless card into medion mim2120 laptop?
I assume you mean "wi-fi" wireless access. The easy solution if wireless networking wasn't built in is to use a USB wireless adapter that simply plugs in to any USB connector on the laptop. These adaptors are available at retailers where you can buy computers as well as from many online sources. The adapter will come with any software and installation instructions you need.
Please take a moment to give this solution a fixya rating if it has been what you needed, and thanks for asking here!
Mar 05, 2009 | PIONEERPOS M55E25R30P PC Notebook
Medion MIM2120 Wiping Hard Drive Problem
what do you exactly mean "to wipe the harddisk drive"? are you referring to 'format'?
Nov 06, 2008 | Computers & Internet
Medion mim2120 Wireless Problems
I had similar problem with Medion WIN 2140. The harddrive crashed, I bought a new drive and had to reinstall Windows from scratch since I had neither a backup or burned the reinstallation CD's. First I installed Windows7 and every driver/application/BIOS available from Medion's download site. At first my WIFI worked OK but somtime during the process og BIOS/driverupdate my WIFI antenna turned off. The antenna can be turned on/off with a easy access button (touchpad to the right of powerbutton) but WIFI button dows not work.
Medion's danish supporters told me that Windows7 is unsupported. So I had to reinstall using Vista. Still not able to turn on WIFI. I'm pretty sure that BIOS prior to version 1.0K (dated 06.01.2010) had a "ON" possibility but is now limited to "OFF" og "LAST STATE".
Medion support wouldn't og couldn't provide me a previous version of the BIOS. In fact Medion DK's support doesn't seem to know anything about their products.
However I have found the solution myself. Launch Manager application is needed for Easy Access buttons to work. Current version of the application is faulty. In registry i found that pressed keys call the file fn.exe, this file is not a part of the OS, Launch Manager or any other Medion driver/application.
I googled for and found the prevoius version 1.4.9 of Launch Manager. This version works without any problems on both Vista and Windows7.
I wrote to Medion support to replace the faulty application on their support site. But with my current Medion experience i daught they will do anything about it. So instead I post this reply to help others.
Oct 15, 2008 | Computers & Internet
Laptop keyboard not working medion mim2120 notebook pc
this and my mouse have also stopped working, idk the problem but i fixed it once and whenever i wanted to turn it off i just put it into sleep and it worked fine when i started it up. i came to a situation where i had to restart the computer and it didnt work again and now i cant fix it.
Aug 18, 2008 | Computers & Internet
Updates not installing
I have found, depending on the update, that downloading them manually to your desktop, then installing them from there usally does the trick. Just write down the KB number of the update and go to and download.
Mar 05, 2008 | Medion MD-40954 Notebook
Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Feb 23, 2008 | HP Pavilion dv6000z Notebook
Medion md40298 Notebook Logo
1,322 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
