It sounds like you have punctured the evaporator coil and it is leaking refridgerant.
That would certainly cause the unit to be low on refridgerant which would cause it to start warming up, and becoming louder. It would also explain the smell.
If the unit is fairly new it *may be worth repairing, You will likely need a new coil.
Expect costs in the 300 to 500 range.
I reccomend getting a secondary place to store the food, and unplugging the unit emediatly if you want to have it repaired.
The reason for that is because the compressor is likely undamaged at this point. but if it runs on empty it will soon fail and then you can double the repair price or more.
Nope the evap line is aluminum and can't be soldered onto the suction line sorry
