Question about Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner
CD loading arm works sporadically
About every five CDs in our top CD burner is not picked up by the arm at least the first time. We receive a message saying there is a problem and sometimes can hit "retry" but if we have to hit "retry" more than a few times, we actually have to go to the duplicator, move the disc slightly and then the arm will pick it up. Rimage's support line is an endless wait and I never get timely help. Any suggestions? I've been to their site and have not seen any support ideas/updates/work arounds for this problem. Thanks!
  • Anonymous Oct 29, 2008
    I have the same problem! Finally someone in the same boat as me. Basically from what I can see, there's too much room in the input bin. In other words, there's too much extra space around the discs to slide around. The main source of the problem is the front left plastic column of the input bin. It doesn't stick straight up, it leans slightly outward (away from the blanc disks. I had to wedge a piece of metal between the front left column and the machine (without interferring with the robotic arm) to get it to stand up perfectly straight (so it keeps the discs in the bin from having too much free space to drift. Looks shitty, but works. Hope this helps.
Hi guys,
We had exactly the same thing (for years!), in our case causing pick failures about once every twenty disks.
The total and complete solution seems to be to upgrade your 2000i to the very latest firmware. I've just completed 500 disks with just one pick failure. Plus, as a very surprising bonus, the machine seems to work considerably faster overall.
MAN, the grief it would've saved us if Rimage had fixed this sooner...
Tony Sutorius
Unreal Films
Wellington, New Zealand
Posted on Jun 25, 2009
Www.rimage.com/DAM_public/5310.pdf
Posted on Dec 14, 2007
The drive does not play cds nor dvds. However, it burns both cds and dvds very well. What is wrong here? How do I fix it?
The image receiver is probably bad inside the laser lens. When the laser light emits and reflects back from the disk, the receiver should pick-up the light - in this case it doesn't. It lights up because you can burn. Try another drive - external (USB) or internal (replace the one inside the computer).
Nov 09, 2010 | Pioneer DVR-212D Burner
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
Mar 18, 2009 | HP Pavilion dv4000 Notebook
Error message E-8302
It sounds like you might have problems with your CDs. If you are burning CDs on your computer to play in the CDJ, you need to remember that it will only play audio (wav), or MP3 files. Also, blank data CDs are cheaper that buying audio / music CDs. When you burn your CDs to play back on the CDJ, you have to be sure to burn them as wav or mp3. AAC, MP4, OGG and the other formats will not work in the player. When you burn the CD, ALWAYS burn at a slower speed than what the computer will automatically burn at. You will have to manually set the speed yourself.
Personally- when i burn my tracks CDs for my CD book, I use trusted name brand blank data CDs such as Memorex, Sony, TDK, Fuji, Imation. I burn them as AUDIO ONLY. To avoid any reading mistakes that could happen with any given CD player, i NEVER burn track CDs as mp3. When i burn the CD, i set the writing speed to 24x, 30x, or 32x. I recommend that you DO NOT burn your CDs at any speed faster than 32x. From my experience, that is the fastest and safest burning speed. If you do these things, and you still have problems with the E-83 02 code, then it will only have to be the kind of CDs your using to burn, or your CD burner in your computer. Notice how i didn't mention Maxell CDs up top. 3 months ago, i bought 2 spindles of Maxell data blanks on sale for $9.99 each. I was happy i got them that cheap, but the CDs themselves were no good. Recording everything the way i do, they had popping noises and scratching sounds through-out the disc. I gave the spindles to my neighbor. He was happy to get blank CDs free. I WILL NOT say that Maxell makes a bad product: I still record on cassettes and Maxells are one of my top 3 choices for blank chrome tapes. But the discs i bought were just a bad batch. Maxell is still a trusted name for blank tapes with us older DJs that started out with recording on tapes before the CD format became way cheaper and affordable.
Try burning your discs as audio only, and burn them at 24x, 30x, or 32x ONLY. Buy better brand name data CDs, and you should have no problems. If you use my method as an example, and you still have problems, then you need to get a new CD burner for your computer. They are always cheaper at Staples or Office Depot. Hope **** works out for you : D
Nov 08, 2008 | Pioneer CDJ-800 Turntable
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
AMSUNG DVD WRITER PROGRAMME DISK ( NERO, BG68-01317A REV.00 )
IF you are burn youor CD make sure is read and writeable drive if not
get a dvd burner or cd burner a dvd is for dvd CD rewriteable
a cd is just regular CD blank CD for both make sure format when your computer
has detect 14x or 16x 700GB storage...
Feb 01, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Clarion M235
It needs a new CD mech. Hopefully you can exchange it from the shop you got it from.
Sep 19, 2007 | Clarion M235-RET CD Player
Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner Logo
285 people viewed this question
Top Rimage Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
