The front panel doesnt work - I keep pressing the light cycle or any button - it simply would not work. HELP
Http://www.cpsc.gov/cpscpub/prerel/prhtml07/07094.html
You should go to this web site if you are on the chart below
there are over 2 million recalls on maytag dish washers due to fire hazards...
Brand
Model numbers MUST
begin with…
AND serial numbers MUST end
with…
Maytag®
MDB3, MDB4, MDB5,
MDB6, MDB7, MDB8,
MDB9, MDBD, MDC3,
MDC4, MDC5, DWU9
SM, SQ, SS, SU, SW, SY, SZ, UB,
UD, UF, UH, UK, UM, UQ, US, UU,
UW, UY, UZ, WB, WD, WF, WH, WK,
WM, WQ, WS, WU, WW, WY, WZ,
YB, YD, YF, YH, YK, YM, YQ, YS, YU,
YW, YY, YZ
Jenn-Air®
JDB3, JDB4, JDB5,
JDB6, JDB7
UB, UD, UF, UH, UK, UM, UQ, US,
UU, UW, UY, UZ, WB, WD, WF, WH,
WK, WM, WQ, WS, WU, WW, WY,
WZ, YB, YD, YF, YH, YK, YM, YQ,
YS, YU, YW, YY, YZ
This is a common problem.to fix this u need to chge the the top controrl panel assly.it is preety easy to chge.to chge the panel u need to open allthe screws on inside of the door.then the white part of the door can be moved apart.the control panel is held to the outer metal door panel by 4 screws.b4 removing the panel remove the 2 screws which hold the control board to the panel and move away the control board.also u have disconnect the ribbon connector which comes from the control panel and connects to the control board.
