Question about Zebra TLP 2824 Printer
Labels spitting out, but blank
I just replaced the thermal labels in my LP2824 for the first time, when it spits the label out there is nothing on it. In SUCKVILLE, please help!
  • 53 Answers
Re: Labels spitting out, but blank
Sounds like you have thermal transfer labels in the printer, you need direct thermal labels.
expose the labels to some heat and see if they turn black, you can do this by quickly running your finger nail across the labels. if they don't blacken then you have the wrong labels.
Posted on Dec 07, 2007
0 characters
3 Points
Zebra GX430t, print two blank label when switch on
this is because printer calibrates every time u power on, this is a default setting, and its good if u using diferent labels all the time. you can change the settings thought driver,and change (when power on - "doing nothing" dont forguet to reboot Thanks Paulo.
Apr 08, 2014 | Zebra GX430t Thermal Printer
Hi. We use UPS worldship and we have a Zebra Z4MPlus printer. It is shooting out a blank label after one label is printed. When there are multiple packages it will spit out way too many labels with blanks...
Things to check for:
1. Make sure that label guides are positioned correctly.
2. Make sure that media sensor is positioned correctly.
3. Make sur that media type is set for non continuous labels.
4. possible sensor fault tis will require an engineer.
Hope this helps.
Aug 22, 2011 | Zebra Printers & Copiers
Blank labels keep feeding out
Disable start up calibration maybe?
May 09, 2009 | Zebra 105SL Thermal Label Printer
Zebra LP 2844 spitting out blanks
Look at the stocks tab in the driver. There is an area in your print driver to adjust the width/height of the kind of label you are trying to use.
Apr 08, 2009 | Zebra LP 2844 Thermal Printer
Spits out multiple blank labels and reports a printing error
I just fixed my coworker's Dymo, which had the same problem. I hope this helps: if you've ever fed it labels in the wrong direction (upside down), you may have jammed it and left a piece of a label glued to one or more of the sensors that let the labelmaker know it's finished printing a label.
1. Disconnect your labelmaker
2. Disconnect/remove any unused labels and set them aside.
3. Remove the face plate (with the DYMO LabelWriter 400 logo)
4. Lift the gray plastic lip (labels go under this) and make sure there are no pieces of paper/labels in there.
Once I removed a piece of an old label and put the LabelWriter back together it started working well again.
Sep 23, 2008 | Dymo LabelWriter 400 Thermal Printer
Printer won't print at all!
Default the printer by holding the feed button down intill the light flashes 4 times and then release to default the printer to factory specs, auto calibrate and save settings to memory. If that does not help its mechcanical and needs service.
Sep 04, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 2824
if you see that it is like printing a card. check your thermal print head maybe its not working.
Jun 23, 2008 | Zebra Eltron LP 2824 Thermal Printer
Printing blank labels between and after printing tags
your printer needs to be calibrated and set label lenth in the driver in both printer preference and printer defaults
Jan 16, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Zebra TLP 2824 Printer Logo
736 people viewed this question
Top Zebra Printers & Copiers Experts
Level 1 Expert
kenneth njonjo
Are you a Zebra Printer and Copier Expert? Answer questions, earn points and help others
