Question about RCA P52960 52" Rear Projection Television
Front screen cover
How do i take the cover off to remove cobwebs
    Novelist:
    Champion:
  • 232 Answers
Hammer, waay easier and safer to remove the back top cover, the front is flimsy when it is removed from the set and if you crack one or both of the screens they cost big money. Be advised that the top back cover has a large mirror bolted to it and it to is expensive. Have 2 people when the last screw is taken out so you don`t break the mirror, not real heavy but very awkward for one person. Once you remove this back cover you can clean the mirror, inside of front screen and all 3 lenses. NO WINDEX, DAMP, lint free cloth and warm water only. Good Luck & Happy Holidays, BMW Rider
Posted on Dec 05, 2007
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
Need to remove front screen from toshiba TP50G50
There is a way to remove entire front screen with the frame----BUT there is a easier way to do this.
With set unplugged remove rear cover---wipe the lens you see there first--light source for picture. With a Swiffer type duster carefully reach up and in and get all the webs out.
Use no force if up against the inside of the screens as that may scratch them---much faster, safer, and easier than removing screen unit from front and avoids possible damage.
SD TECH
Jun 01, 2012 | Toshiba TP50G60 50" Rear Projection...
Cobwebs proscan ps56700 inside screen
It can be done from the front but from the rear is actually more easy and safe--removing front screen and frame entails some danger of damage to the screens.
I have over many years of outside/home service calls encountered this.
As a outside technician I want the quickest and safest way to do this.
With set unplugged simply remove rear cover:
Use a swiffer type duster to reach up and inside and gently get all the webs out(do not use force when against the inside of the screens) and if the handle is long enough you will be able to remove all of the webs.
Also when doing this you will see with cover off 3 large black lens at the top of the chassis above the circuit boards.
They are the light source for your picture--clean them with a lens cloth or a paper towel with Glass cleaner sprayed on it---Do not attempt to clean the mirror in the rear as it is a film material and is easily scratched.
If the lens were dusty/dirty and then cleaned the picture will be brighter and sharper looking----that should be done about one time a year.
If you have questions make a comment here on this page(make a comment button).
Apr 21, 2012 | Proscan PS56700 56" Rear Projection...
Cobweb behind the screen.
You can try and use a air compressor or canned air and blow inbetween screen and protective cover and see if that removes the cobweb. Give that a try and let me know if that works for you.
Good luck... HDTV GURU JAY
Mar 14, 2011 | Televison & Video
Can the front cover be removed for cleaning?
yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Apr 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Mitsubishi VS50609 has cobwebs behind the ribbed screen and I need to know how to remove the ribbed screen, I already removed the clear cover smooth cover. Sandy
set should have the clear screen cover (protective) and two more screens behind that. Easy way is to unplug set and remove back cover--cobwebs are usually behind on inner screen.
With the back off I use a swiffer like duster and reach up and get them all out--gently on the inside of the inner screen so you do not scratch or mar it.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 09, 2009 | Mitsubishi VS-50609 50" Rear Projection...
How doI take the cover off to clean the inside of the protective screen? sony KP-53v80
I removed about 6 or so screws took back cover off and used a duster to clean the inside screen it cured my cobweb problem.
Sep 12, 2009 | Sony KP-53V80 53" Rear Projection...
Cobweb inside of TV
i did mention this in my problem post incase it can help you but in the event where you overlooked it try some dust-off it may help you better than it did me
Jul 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Clean behind the screen.
hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Nov 24, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
RCA P52960 52" Rear Projection Television Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
