Question about Acer Aspire L100 PC Desktop
Cleaning The Tower [inside]
I have an Acer Aspire T180. I would like to clean inside the Tower. I removed the two screws. But I could not get it to slide off. Have I missed something? Is there something else holding it in place? I would appreciate some advice. Thank You
    Problem Solver:
  • 12 Answers
There is a black lever just above the bottom screw...after removing the screws, push down on the lever and it should release the case to slide off
Posted on Jan 29, 2009
  • 56 Answers
With the palm of your hand, hit and slide the casing back, sometimes casing can be very tough to get off so dont be afraid to use some force.
Also when cleaning the inside try to use compressed air and not a vaccum and when cleaning the fans put your finger in the fan to stop it spinning, the fan can generate enough electricity to fry everything if the system is not turned on.
Posted on Dec 05, 2007
Replace hard drive
Inside the tower under the CD Rom rack could be inverted but its a silver or black metal box mounted in a rack
Mar 28, 2014 | Acer Aspire™ T180 PC Desktop
Red light on my tower and it wont work
The red LED indicates that the hard disk is active. Replace hard disk.
Oct 19, 2013 | Acer Aspire™ T180 PC Desktop
I need a picture of what the insides of the tower looks like a plug fell out
Tell me what is the wire color ? it should be nothing other than the LED light / reset / power button.. Just confirm me if all the front panel buttons are working ?
this is the motherboard picture but it wont help unless you find what is not working in ur pc - https://www.blueraven.com/BlueRavenResource/ItemimagesLegacy/Z3807-0.jpg
Jan 28, 2013 | Acer Aspire T180-EA350M (AST180EA350M) PC...
Can't get the side panel off my acer aspire ast 180-UD360A
Hi I was suppose to provide you the instruction however it would be better if you will see the images including steps on how to remove the side panel of your tower..This website will help you a lot ..
http://global-download.acer.com/Step5.aspx?Step1=Desktop&Step2=Aspire&Step3=Aspire%20T180&BC=Acer&Category=Document
Nov 17, 2011 | Acer Aspire™ T180 PC Desktop
How to open the Acer mini-tower Desktop?
Acer Chasis has two screws at the back, which you should open. After removing the screws press the Black T-Shaped button down and pull the side lid backwards to open the chasis as marked/ shown below: -
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 27, 2011 | Acer Aspire™ T180 PC Desktop
I can not get the side cover off my acer t180 I need help!
Viewing the back of the computer, there are two screws to remove on the right side panel, at the rear.
One close to the top, one close to the bottom.
Make sure the screws are going through the side panel itself.
After you remove them you pull back on the side cover with one hand, holding onto the computer tower with the other hand.
Sometimes the side cover is tough to pull back.
(Be SURE the computer is unplugged from power)
Would appreciate hearing the outcome of this.
(Post in a comment. Believe upper right of page - Comment)
Jan 08, 2010 | Acer Aspire™ T180 PC Desktop
Opening side panel of acer aspire t180
You have done half the work toward the solution by removing the thumbscrews. The other half involves sliding a spring-loaded lever above the lower thumbscrew toward the bottom of the case. While the lever is slid toward the case bottom, push on the side panel in the same direction as the screws, i.e. toward the rear of the case. The side panel should slide just slightly, allowing you to then lift it off to access the inside. Note that when replacing the side panel, follow the above steps in reverse order.
When replacing the side panel, note that if the panel is not correctly replaced, the thumbscrews will not be able to be installed as the lock lever will not be set properly.
Jan 23, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire L100 PC Desktop Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
