Shrink-it need instructions on how to use shrink 3.2
    Scholar:
  • 79 Answers
Are you talking about DVD Shrink? Actually it is quite simple..
First you open the DVD from the menu list, and it will run through a process of loading the DVD movie.
Then you decide if you wish to extract all the languages. If not, the compression will be less, and the quality better. Just uncheck the languages you do not need.
Then, click the Backup Button. A wizard will come up and you decide where you wish to save you movie. It will compress the movie and save it so you can burn it later. Or, you can burn it right then to another DVD (although I would prefer to do this separately.)
Now, I do not use Shrink anymore, as many protections that the new movies have cannot be broken, and Shrink will not work on them anymore.
Posted on Dec 05, 2007
Electric cord chipped power shorting, how do we fix it
You will need a wire stripper, solder, solder flux, heat shrink tubing, a heat gun (hair dryer will do) and a soldering iron.
1. Cut the cord where the chip is.
2. Strip the wire on both sides by about 1/8". You should have 4 exposed wires from the two wires inside the cord.
3. Apply some soldering flux to the exposed end.
4. Heat the exposed wires and apply solder. This is call tinning and will help when you are attaching the wires.
5. Cut the heat shrink tube about 1/2" long, you will need two. Insert the heat shrink tube to both wires that is to be soldered.
6. Solder the wires together by applying heat and attaching the wires when the solder melt.
7. move the heat shrink over the soldered area and use a heat gun to heat the tube. It will shrink and provide insulation as well.
**If you don't have soldering experience, you might want to take it to an experienced technician. Bad solder or poor insulation can cause expose wires and poses an electric shock hazard!
Jul 09, 2014 | BonJour Power 1800 Grill And Griddle...
Tip
The Easiest Way to Use DVD Shrink
<b>DVD</b> <b>Shrink</b> is a freeware DVD transcoder program for Microsoft Windows that uses a DVD ripper to back up DVD movies. The final versions are 3.2.0.15 (english) and 3.2.0.16 (german), all other versions like DVD Shrink 2010 are scams. As commercially-released video DVDs are typically dual layer one of DVD Shrink's functions is to process the video into lesser quality and/or discard extra content such as foreign-language soundtracks so as to fit on a single layer (4.7 GB) DVD.<br /><br />DVD Shrink is freeware, and it is only to be used to create backup copies of DVDs you already own. It is illegal to make copies of rented or borrowed DVDs, or to copy them and sell them for profit. The reason we need DVD Shrink is because a regular DVD movie doesn't fit on the average 4.7gig size DVD disc, we <b>use</b> DVD Shrink to cut the contents down to size as to fit on the disk.<br /><br />This article will provide you <b>how</b> can you use DVD Shrink to copy DVD movies step by step. All you need is a DVD Shrink software and you will be able to store and duplicate all your DVD discs.<br />To use DVD Shrink, Things you will need:<br />* DVD Shrink program <br />* A DVD movie to backup<br />* DVD blank disc<br /><br />Guide: How to Use DVD Shrink 3.2 <br /><br />Step 1. Start the DVD Shrink Program and choose Open Disc from the menu above. <br /><br />Step 2. A box will appear. Choose which DVD drive your disk is in. Mine is in F: drive. The name of the disk will show up in brackets. In this case it is called NEW. <br /><br />Step 3. Press OK. It will read the DVD.<br /><img src="remote_image20110803-18141-1qmdivp.gif" /><br />Step 4. Shrink DVD size.<br />1) A breakdown of the movie will be displayed in the right hand column.<br />2) You cannot fit all this on your blank dvd so now press Re-author.<br />3) In the right column there will be a heading called Main movie. There will be a file under this heading. Drag this to the left column. The file size is usually more than 4,700mb and has to be compressed.<br /> <img src="remote_image20110803-18141-17xn34v.gif" /><br />Step 5. Click on the "Backup" icon. This is where you will choose a folder for your ripped files. Once you make a folder, make sure the box is checked next to "Create VIDEO_TS and AUDIO_TS subfolders" and click "OK".<br /> <img src="remote_image20110803-18141-sc8anv.gif" /><br />The movie will now play quickly in the viewing box, and you will see the progression of the rip. Once the rip is complete, the movie can be burned to a DVD-R automatically via DVD Shrink using NERO. Or if you have different DVD-burning software, you can open that manually and burn the ripped files as you normally would.<br /><br />Here we also recommend you the best DVD Copy software, 1CLICK DVD COPY PRO, which is a fast, easy-to-use, full featured program for copying DVD movies onto DVD discs. With 1CLICK DVD COPY - PRO, you can make a perfect copy with just one click. You can free download DVD Shrink via the link below:<br /><br />Tags: how to use dvd shrink,how to use dvd shrink 3.2,how to use dvd shrink to burn a dvd,dvd shrink free download,free dvd shrink,shrink dvd software<br /><br />Related Resources: <br /> <p><span><a href="http://www.dvdcopymac.org/burn-dvd/burn-movies-to-dvd-on-mac.html"><span>burn movies to dvd on mac</span></a>,</span><span> </span><span><a href="http://www.dvdcopymac.org/">dvd copy mac</a>, <a href="http://www.dvdcopymac.org/resource/free-dvd-copy.html">dvd copy freeware</a>,<a href="http://www.dvdcopymac.org/burn-dvd/convert-burn-m4v-to-dvd.html"> m4v to dvd</a>, <a href="http://www.dvdcopymac.org/guide/how-do-you-copy-a-dvd-in-windows-7.html">copy dvd in windows 7</a></span><br />
on Aug 03, 2011 | Computers & Internet
How to partition disk
hi!
U can partition the hard disk in vista easily
1. open run command
2. type diskmgmt.msc
3. Press Enter
Now u can shrink the volume of any drive to make partition in disk management
Thanks
Apr 22, 2010 | Microsoft Windows Vista Home Premium...
I AM CHANGING THE DRIVER DOOR ON MY HONDA ACCORD AND I HAD TO CUT THE WIRES AND I NEED HELP PUTTING IT BACK TOGEHER
You will need a soldering iron and some acid core solder. Skin back about 1/2-3/4 inch of wire on each wire, add a peice of shrink tube, twist the wires together and solder them together, side the shrink tube over the soldered area and heat the tube to shrink, or use some electrical tape. Make sure everything is taped up well to keep water out.
Mar 11, 2010 | Honda Accord Cars & Trucks
When I send an image in outlook express, it is received by others as a red x.
Today's high resolution digital cameras produce multi Megabyte photos. These are great for printing but cause a heavy burden when sending over the Internet.
Shrink Pic allows you to send dozens of photos as email attachments - quickly and with no effort at all!
All you need to do is install Shrink Pic. It automatically detects when you're sending large photo files and compresses them in the background.
There's no setup, no operating instructions, nothing, nada. Just send your photos normally and Shrink Pic takes care of shrinking them.
Also, make sure you get no errors when sending out the email in outlook express.
Jan 02, 2010 | Microsoft Outlook Express
No picture, last night color was going away, then today no picture
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more clear and works fine.
0667c5f.pngSOLUTION
Nov 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Tv picture shrinks
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Nov 17, 2009 | Philips 9P6031C 60" Rear Projection...
Picture shrinkage to 16:9 rather then 4{3
This is a common problem. You can get parts and instructions from www.TvRepairKits.com . Find your model on their site and get the shrinking and expanding kit.
Jul 01, 2009 | Philips Magnavox 51MP392H Rear Projection...
Rose Art Super Shrink Art Instructions?
I emailed Mega Brand's Consumer Affairs Dept and received the following instructions re Rose Art's Super Shrink Art:
Super Shrinky Dinks Art
Instructions:
Step 1: Place a sheet of Shrinky Dinks over a design with the rough side up. Trace the design including the thin cut line around the edge. When tracing letters, draw your own cut line approximately ¼” away from the letters.
Step 2: Color and decorate your artwork with the other colored pencils. Be sure to stay only on the rough side of the Shrinky Dinks.
Step 3: Ask an Adult to help you with this step. Cut out your colored design from the Shrinky Dinks following the traced cut line. Make sure all of the edges are smooth. Do not leave any sharp corners or they will become very pointy when the art is shrunk. Use a hole, punch if you want to make a key chain.
Step 4: ADULT SUPERVISION REQUIRED FOR BAKING. Pre-heat your home or toaster oven to 325*F (163*C) NO MICROWAVE. Put your creation onto a non-stick cookie sheet with the colored side up. Place in oven and watch until it shrivels up and then flattens out.
Dec 28, 2008 | Toys
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
