Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Toshiba tp50f60
By scmedrano on Dec 04, 2007
light on not powering up
Same Problem
May 05, 2009
-   when i plug in the tv the front led flashes and nothing happens plz help-   plainman85
Apr 07, 2009
-   When attempting to power up, the front LED blinks, an internal sound (similar to the one a hard drive makes) can be heard but no image or sound comes up.
The LED is labeled TEMP/LAMP. My guess is that is one of the two. Since the TV has not been turned ON for the whole day, I assume that it's the lamp.
I have a Hitachi Ultravision 55V569A
-   Ricardogarci
Apr 26, 2008
-   tv is showing double-   Guest
Solution #1
posted on Dec 05, 2007
Somewhat Helpful)
ctf1800
Rank: Wiz
Rating: 85%, 4408 votes
f your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset. To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
this site gives you the crun around it is worthless so
Answer
picture is small an blurred model number 8p5434c101 phillips magnavox projection manufacture date... (More)
Answer
screen size options will not fix the problem of improper fit - ie. scores running on the bottom of... (More)
Answer
i have a phillips 60" rear proj. the converge will not adjust what is the secret repair and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
