Question about Juicers
How do u wash this?
I'm trying to unscrew the juicer to wash it but i don't know how any ideas??
  • 5 more comments
  • Anonymous Jan 13, 2008
    I can get the lid off but not the pulp collector. Any ideas?
  • cecilita Feb 21, 2008
    Yes I have a juiceman II and I don't have the instructions can you tell how to clean it?
  • kogizen Mar 31, 2008
    I have the Brentwood product and lost the manual.  I can not get the lid to release for cleaning?  Any suggestions?
  • Anonymous Apr 08, 2008
    I want to disassemble the cutter strainer in order to clean it.
  • Anonymous Jun 23, 2008
    I can't get the stainless stell screen off to clean it.
  • DGETZ22104 Jul 08, 2008
    i don't have a manual for the hamilton beach 350 juicer. i dont know how to get the metal strainer out to clean it or if it even comes out. please advise. thank you
  • Anonymous Apr 12, 2009
    I purchased a used Juiceman 2 model jm2 yesterday and do not have the manual to tell me how to take it apart. Can't figure out how to remove the metal basket. Can you tell me or how can I get a manual.
    bevnorth@aol.co,
Okay...Here goes: I figured out that there must have been a "keyway" tool of some sorts, so I used a knife instead...I have a j6-6 model (salton) and on the rear oif the machine just below the upper pulp catcher section, there is an "opening" of sorts. take a steak knife and insert this into the opening..(UNPLUG THE MACHINE FIRST!!!)..grasp the stainless steel strainer and while twisting the knife in order to apply pressure and "jam" the drive shaft underneath , twist the strainer basket counter clockwise...It will release and the rest is easy...Hope this helps..ChristianMagician in Diamondhead
Posted on Jul 16, 2008
You have to unscrew the metal blade. See the three screws which connect the grater? Unscrew those. I know, it's a terrible design. Very unpractical. So once you unscrew the metal grater, you can twist off the top plastic part of the machine. The top part I'm referring to shoots out the pulp. That whole thing twists off. Then you can clean your juicer. It's a **** design. It's amazing that this is Juiceman 2. Just imagine how crappy Juiceman 1 is...
Posted on Jun 15, 2008
  • Test Test Jan 20, 2011
    Thank you! This helped me out a lot!!
Here, try this page...it has a user manual on it...
http://www.csnstores.com/Hamilton-Beach-67800-HMB1074.html#ProdDetails
Posted on Mar 08, 2008
If you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Posted on Dec 04, 2007
I am taking my juicer apart. I took the three screws out and the grinder plate. How do I get the filter out that is beneath the grinder plate.
Don't take the screws out! That plate is not meant to come off.
The filter unit is removed from the base by unscrewing it counterclockwise using the two holes in the plate that you unscrewed. The juicer originally came with a plastic tool with two prongs that fit in the holes and acted like a sort of handle you could use to unscrew the assembly.
If you don't have the tool, you can use two small screw drivers or jury-rig a tool out of a piece of coat hanger shaped into a U to gain leverage to dismount the entire filter/blade assembly for washing.
Hope this helps!
Mar 03, 2011 | Jack Lalanne Power Juicer 250 Watts
I was putting re-juicing a clump of wheatgrass and the omega juicer stopped. Now I can't unscrew the front piece off to get the wad of wheatgrass out. Help! I tried to run it under hot water.
I soaked it in hot water and it loosened enough to unscrew the outer portion and also moistened the stuck wheatgrass enough to pull it out. whew.
Jan 20, 2010 | Omega 8001 Wheatgrass Juicer
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
I do not know how to clean and take it apart
I did some research here on Fixya and this is what another expert had to say.........pull the metal bar forward and down to open up into the blade compartment. your juicer should have come with a handle type key wrench thing that you stick on top of the blades into holes to unscrew blade holder, while unscrewing that hold the blade still.
Hope this helps you......best wishes.
Oct 05, 2009 | Jack Lalanne Power Juicer 250 Watts
How do you take apart the jack la lannes juicer for cleanning
I had the same problem because I bought it used. After reading that I needed a key that fit in the holes I used a pair of chop sticks and it twisted right off.
Sep 15, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne power juicer
I seem to be able to put the crescent too in but the blade just spins and doesn't seem to be connecting to anything to pull it out. Talk about frustration!!!!!!!!!!!!!!!!!!!!!!!
Jul 21, 2008 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
516 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
