Kodak easy share 5300 all in one printer
Printer won't let me print . The window says that the printhead missing not installed correctly or has come loose. It says that it has to be removed and reinstalled but I don't know how to remove it. I have been using the printer every day and it has been fine but when i turned it on to day this is what it told me and it won't do any thing. Can you help? Al
  • 5 more comments
  • Gerhard
    Gerhard Dec 18, 2007
    the panel claims printhead to be missing or loose. Several removal and re-insert attempts yielded same result - customer support offered firmware fix to no avail
  • Anonymous Dec 21, 2007
    states printhead loose but i dont know where it is or how to fix it
  • Anonymous Dec 28, 2007
    have the same problem with printhead.talked to kodak support and they sent me a new printhead, but installed it and the same thing error printhead missing. need help
  • Russ46 Dec 28, 2007
    i have the same problem but it occured when i took the printer out of the box and installed the print head and ink for the first time. what is the fix for this problem? how do you even remove the print head?
  • stotty Feb 05, 2008
    comes up printhead lose or missing cartridges not in i took them out and reinstalled them severall times still got same problem any answers please
  • kdswank214 Aug 19, 2008
    Someone please help me figure out how to install a new printhead.
  • maxuloaa Nov 09, 2008
    Identical problem as described but with Kodak 5500. My printer worked for about 2 hours before this printhead error occured. I managed to get onto Kodak via their chat line. The chap who answered seemed rather eager to have me replace the printhead. He's so disinterested he begins telling me how to upgrade my camera firmware. Yeah - camera. I have to remind him we're talking 'Printer' - like hello 'Printer...wakey wakey'.
    So, it seems that Kodak knows about this problem. Are they remaining very quiet about it. Sure. It's unheard of for a manufacturer to come out and declare that their brand of printer is frequently faulty.
    Problem Solver:
  • 11 Answers
Kodak website has instruction manual that you can download. It tells you how to remove and reinstall the printhead. Basically you remove the ink tanks first by pressing the lever at the front and angling them upward. Once both the inks are out you press on a lever on the upper left side of the printhead (the black thing the ink cartridges were resting in). That lets the printhead come out. Now the tricky part is to get it back in. You put the printhead back in until it clicks and then gently put in the ink cartridges. I say gently because if you press too hard you may cause the printhead to become loose which means you will have to start over again. Everything "clicks" when it is in correctly.
Posted on Dec 10, 2007
Hi i went to kodaxs web sight and installed there up dated version and so far my printer works and doesnt tell me my printer heads are missing etc so far mines worked for aprox 4 months
Posted on May 14, 2008
Sorry guys, I gave up on this lovely looking machine. No good looking nice if it doesn't do the job! Bought one, set it up and within one print I got printhead error message, missing or loose. Spent hours trying to solve it. No joy. Took it back, swapped it in the store for another and guess what...same problem after 2 prints. Kodak Support said do a firmware upgrade, that'll definately sort it out. It didn't!!! It took hours to do as the machine shuts off in error mode - not easy to get around this problem. I contacted them again once the firmware was finally done and they said they'de send a new printhead. I said, no thanks it's my second new machine, I'm off to get my money back!
When I took it back the second time, the guy at the store apologised, saying every one sold in the past month had now been returned. Sounds like quite a problem when you read the above and do searches elsewhere, judging by the comments from people with this same issue! Why oh why is there nothing about this problem on Kodaks web site support either?
Posted on Dec 30, 2007
Same thing here everybody.Sounded like a great deal until I got it home and received the printhead missing,installed incorectly error message.Took it apart aboutt 20 times,shut it off,unplugged it.I called Kodak and the tech had me do what I already tried 20 times before.He did have me hold the photo and copy button at the same time( he said this would reset it) to no avail.I asked if others had the same problem in which he denied . So off to Sams I go and try again with another printer.
Posted on Jan 14, 2008
Sales lady at Sams Club showed me the 5300. We need to send out pictures for Christmas and this looked great. Just $99.76 and the cost of print cartridges was less than half of other printers. This should pay for itself very quickly. Got two, one for house and the other for a gift or maybe the office.
CAREFULLY followed all instructions and slowly put all the parts in place. Printed the calibration sheet, put it in tray to scan, push start and BAM Error Code 6203 shows on display. Error code 6203 is not in any of the documentation. Error code 6203 is not in the Kodak Knowledge Base or avalable anywhere in their support website. I suspected a problem with the Scanner.
So used Google and found this site with all these complaints for the 5300.
I should have known, inside the box is a paper with a big red stop sign that says DO NOT RETURN TO THE STORE, call Kodak technical support. What is the name of the comedian that says "Here's Your Sign" Bill Engvall?
Well I feel like a dope for not seeing it. As a consumer, it sure looks like Kodak is dumping this product at fire sale prices on trusting people. Then we spend time, energy and frustration to identify,download and correct defective software. Hey I have a full time job, I am not willing to work for Kodak for free. I will not dink around with a non-functioning product that Factory already knows about. Thank goodness I did not give this as a gift or take this to the office to spend company time on Kodak's problem.
Kodak, you can fix this yourself after Sam's Club sends it back. Good luck selling it again. Hope other people read this before they purchase from Kodak.
Don't bother with sending me an email, I am gone and there's YOUR sign Kodak.
I live in Lyon France, i ve bought a Kodak 5300 yesterday and returned to the store to change the printer head cause a circuit burns. I plug the printer in different places, each time (3) a new printer with a new everything and 3 times the same problem: a printer head circuit burned. but the message was PRINTER HEAD MISSING OR NOT CORRECTLY INSTALLED.
and my apppartment's electric circuit works correctly.
Tomorrow 'ill change it for another brand,
Posted on May 13, 2008
SDtester
  • 41 Answers
SOURCE: kodak easy share 5300 -
The first thing you should try is running a printhead cleaning using the kodak software or from the local user interface on the printer. from the printer press the [menu] button. press the down arrow untill Clean Printhead is highlighted. press the [OK] button. Select "Deap Clean" and press [OK]. If this does not work you can mannually clean it. You can search online for how to clean inkjet printheads. I use distilled or de-ionized water and a LINT-FREE cloth. Dont use paper towls or anthing that could leave lint behind and clogg the nozzels. when you wipe the printhead make sure you only wipe in the direction of the nozzels, with the grain. Do not use a circular motion. You want to wipe from the front to the back or back to front of the printhead. Not left to right. I hear windex works as well but i have never tried it. Do some research online and use you best judgment. If none of this works you may have to contact kodak and see about getting a new printhead, they dont sell them sepeartly.
Posted on Feb 14, 2008
SOURCE: Kodak 5300 Printhead problems
Contact Kodak! I received a new printhead and that solved the problem. Great customer service!
Posted on Sep 02, 2008
SOURCE: How do you remove the printhead of a Kodak EasyShare 5300 printer?
I have tried what is suggested , I am not getting anywhere with this. I wasn't able to move my finger to the left of anything. What am I doing wrong!
TY
LindaPNY
Posted on Sep 22, 2008
  • 1218 Answers
SOURCE: Kodak Easy Share 5300 Printer error Error
Error code "6203" can be resolved as follows:
First, you need to open the access door of the printer and disconnect the power adapter from it.
You then need to wait for at least 30 seconds for the printer to get reset.
As a next step, you can connect the power adapter back to the printer.
You can turn on the printer, if required. Once the printer gets powered up, a message "Printer access door open" gets displayed.
Once this message gets popped up you can close the access door of the printer. get more help for Printer Error Code 6203
Hope this helps you.
Posted on Sep 20, 2010
  • 16 Answers
SOURCE: My Kodak Easy Share 5300 Printhead needs to be
Take the printer to the place you purchased it from. Throw it through the window and steal another make. Everyone will understand
Posted on Oct 16, 2010
My Kodak Easy Share 5300 Printhead needs to be replaced. Where can I get one?
Call Kodak tech support at 1-800-421-6699. Tell them that you are missing colors and have already tried cleaning and reseating the printhead (which I recommend you try first). Normally they will send you out a new one for free.
Mar 02, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
My KodakEasy Share 5300 will not print in black.
92b8b47.jpgThe Kodak AiO printers 5000 series and ESP series PRINTHEADs has orange protective cap that need to be remove to fit on the printer carriage. For the ink cartridges 7b91cbc.jpgthere is also a orange protective cap.
Issue that its not printing black and deep clean and removing the printhead and reinstalling the printhead (reseating printhead) is already done and still no black when printing. The printhead should be replace. For futher assistance call 1 800 421 6699 Kodak AiO printer support line
Nov 16, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer will not print in black and white. i have already cleaned the print head and that changed nothing. my printer is a kodak easy share 5300
have you done the deep cleaning?If yes Please try also to Calibrate the printer.
Now if this solution did not solved your problem it means the nozzles of the printhead that you are using is already clogged Please call kodak for Printhead replacement Toll Free 1 800 421 6699
Nov 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5500 AIO easy share printer will not print black ink.
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak easy share 5300 has printing issues. I
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 29, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Paper Jam Clear Jam
Try this one Take out the inks and printhead Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open Close the cartridge door once the cord is unplugged Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..." Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message. Thanks Josh - Kodak Tech Support
Printer will not print
1-Deep clean and calibrate the printhead
2-Try a firmware update @ www.kodak.com/go/downloads
3-Try a removal and reinstall of the printhead and inks
If all this fails, call Kodak Aio support : 1-800-421-6699 (USA)
Jul 08, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
1,260 people viewed this question
k24674
Marvin
Marvin
