Question about Nikon FE 35mm SLR Camera
Shutter The shutter remains open at all speeds except M90 until rewind lever is pushed to off position.Fresh batterys have been installed.
    Champion:
  • 206 Answers
This is a fairly common problem with Nikon FE . It is usually caused by poor connection ( usually dry joint ) between the light meter board ( all of this is just under the top cover on the right hand side and the top cover is quite easy to remove ) and the shutter and you fix it by resoldering all the connecting wires between the two.
Posted on Dec 05, 2007
I have a nikon fe shutter jam
Turn the speed dial to M90, This will reset the camera, Then make sure you have good batteires before you tke it off of M-90, Battery check on side of camera,. Top cover rewind side
Sep 25, 2013 | Nikon FE 35mm SLR Camera
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
The shutter will only close in the B or M90 postion. It opens fine, but won't close. What should I do?
Try a new set of batteries. The shutter is electronically operated at all speeds except the B and M90 settings. If the exposure meter works with a new set of batteries but the shutter still does not, then you'll have to take it in for service.
Feb 20, 2011 | Nikon FE 35mm SLR Camera
Ive just loaded a film, following the instructions, shut the back and wanted to advance the film, but the lever wouldnt extend the full way, it only goes to the on position
I have the same problem with a Nikon F2, got it off my grandfather and its been in his attic for at least the last 10 years. I don't know if parts have seized up or if im doing something wrong. have put in new batteries, but film advance lever won't go past "on" position. have tried pressing shutter but it doesn't help. Also film winding knob will not lift up enough to load in a film! any solutions!?
Aug 21, 2010 | Nikon FE 35mm SLR Camera
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Shutter remains open
The problem could lie in the meter/speed dial unit or in the shutter itself. New parts are no longer available for that model. You may be able to find a good one on one of the auction sites or even Craigslist. A good used one would be less than a repair even if parts were on hand.
Feb 11, 2008 | Nikon FE 35mm SLR Camera
Nikon FE
TRy firing the camera in the M90 setting. If it fires properly, use the battery test switch. If the battery LED doesn't light up, replace the batteries (2 MS76 type). The FE requires healthy batteries to operate the shutter. If the meter is calling for a slow shutter speed (low light or lens cap still on?). If the batteries are good, but the shutter still won't fire normally in sufficient light, looks like you're in for a repair shop visit.
It may be fatal as there are no parts available for the FE series. The main components that cause this problem are the FRE/ASA unit and the meter itself. The FRE is located under the rewind knob side of the top cover. It is made of glass and can be damaged by impact. The meter is under the speed dial and can also cause this type of problem. Neither is a easy repair.
Nov 25, 2007 | Nikon FE 35mm SLR Camera
Shutter jammed
Did you set the camera to M90 AFTER you installed new batteries? The camera will work without batteries in the B and M90 settings, but when you install new batteries, reset the mirror by turning the dial to M90. If this doesn't correct it, I wouldn't recommend opening the camera - take it to a repair shop.
Nov 23, 2006 | Nikon FG 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
283 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
