Question about Mitac Mio P550 GPS Receiver
Mio P550 how to change hardware id
I just keep getting this message up, (hardware id changed) when i try to go to maps can any body help?
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
1. Activate the TeleType GPS program
2. Select Tools>GPS Status>Status.
3. Look closely at the GPS output that is displayed in the View Status menu. Data should be flowing even when the GPS receiver has not locked in the position.
The data string that begins:
GPGSV... is "bad data" because the receiver has not locked into the satellites.
Whereas:
GPGSA... is "good data" indicating that the receiver has locked into the satellites. Remember - "A-Okay"
4. Once the data is flowing, go outside away from buildings, select the Satellites tab (Tools>GPS Status>Satellites), and watch the satellite signal strength
Posted on Dec 06, 2007
    Genius:
  • 1,153 Answers
Do a hard reset. Pull batt. let stand for 30 min or more.
I have a Mio P550 with Tom tom 6 installed, when I try to run Tom Tom all I keep getting is no valid GPS
Hi Dave,
First off, go to your GPS settings. Make the GPR Program Port: COM4. In the Hardware tab, make the GPS Hardware Port COM2 and the Baud Rate 4800. In Access, have the Manage GPS Automatically checked.
Download the VisualGPSce freeware program from this site install and run it. Make sure you're outside (sorry), you should see the to bars filling and after a while the red light in the bottom corner will turn green meaning you have a lock.
Hopefully now when you turn TomTom on, you will have your position shown. I always need to start VisualGPSce before kciking TomTom off.
Jul 07, 2010 | Mitac Mio P550 GPS Receiver
MIO P550
oprn that folder and there you find the licence detail and fill in the licence detail and then turn off and turn on device and it will be done.
Dec 05, 2007 | Mitac Mio P550 GPS Receiver
My gps need install windows ce but install because I connect the cable to the computer but the computer gives unknown device message
If you GPS is at the point of needing windows CE installed then it is in a bad way. This is not done in the normal way on the Mitac Mio. It is setup using and SD cardspecific keys assigned by mitac to perform only a minimum of functions for its GPS hardware.LikeRESET +POWER then selecting different options specific to the GPS
Then getting maps on it is also different from a straight install. I suggest you contact MIO and have them reinstall Win CE and the maps for you before you compromise it totally so that it cannot be undone
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Mitac Mio P550 GPS Receiver
I have a Mio P550 Digi walker. How do you open the battery chamber in order to change the battery? Many thanks cacameron@btopenworld.com
I removed the rubber infill that covered a hidden screw. Released screw and then removed back plate. Removing the battery then required care as it is stuck with two sided tape to the Mio internals. Here I used a knive to prise/cut free.
Sep 14, 2009 | Mitac Mio P550 Pocket PC
File format error
search on the internet for other file, because yours is broken. After you have it, overwrite the old file.
You can try http://rapidlibrary.com/index.php?q=canada+fbl+maps
Apr 08, 2009 | Mitac Mio P550 GPS Receiver
I have problem when going into the maps i gat an error "hardwareIDchange" i need to reset it and load the maps please help
It can be fixed...this is happening because you changed the sd card that contains the gps software. Uninstall the gps software from the device ( remove installed programs) and then install again. If it shows you again the same error, your gps software is pirated and you must buy an original one, or find a better cracked one ;). Remember : DO NOT DUPLICATE ORIGINAL SD CARDS because the licence file will not work and you will get that error "hardwareIDchange" ( "hardwareIDchange" it says that your sd card hardware id has been changed)
Feb 22, 2009 | Mitac Mio P550 GPS Receiver
Mio P550
why not go and read crash.txt?
Or, just install MioMap once again?
Jul 29, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 reboots but does not take any touchscreen inputs
I had the same and contacted MIO (use the phone number for your country,
http://www.mio-tech.be/EN/support/support-overview.php
). It was related to the shock the screen got and they graciously changed it for me (it was during the second year of the warranty). If the warranty has expired, you are probably looking to about a hundred bucks expense.
Courage,
Jul 02, 2008 | Mitac Mio P550 GPS Receiver
Problem with gps not connecting.
I have Google maps for Mobile working on Mio P550 with GPS Program Port: COM9.
GPS Hardware Port to COM2, baud rate 4800.
http://blogs.msdn.com/windowsmobile/archive/2006/06/07/620387.aspx
Dec 24, 2007 | GPS
Mio p550
I dont know about the charges but did you "format" the card?
Jul 01, 2007 | Mitac Mio P550 GPS Receiver
Mitac Mio  P550 GPS Receiver Logo
775 people viewed this question
Top Mitac GPS Experts
gerry bissi
Marvin
Marvin
Computer Links
Are you a Mitac GPS Expert? Answer questions, earn points and help others
