Question about Compaq Presario 12XL125 Notebook
Display off center
I received this Presario 1200 notebook with a broken 6 wire ribbon to the monitor, I've repaired and monitor now works fine, but is off center. It needs to slide down about 2 inches and to the right about 3. Is there adjustments?
Thank you
What resolution are you trying run it at? the presario lappies screen wont centre with any other resolution than 800x600. try it bigger than that and it will appear off centre.
Posted on Feb 02, 2009
  • 22 Answers
Laptops are very hard to work with and are very fragile. You can tinker with the connection and get it to work better but I would suggest that you just buy another monitor for it and replace it. Once the ribbon is broke there is not much you can do.
Posted on Dec 10, 2007
Presario cq56 laptop have no display
Plug in another monitor on the monitor output - if that monitor works then the problem lies with the laptop display. If the external monitor does not work also then the anomaly lies with the video circuits of your laptop. In either case , repair is expensive and not cost effective - better off just getting another computer.
Jun 19, 2015 | Compaq Presario Notebook
Droped my compaq presario c700 after then display come snow and too many line i already chek my ribon its ok have any soluation
Please connect your laptop with an external monitor (LCD or CRT) by using VGA cable, and check it is working fine or not, If it work's fine we can confirm that your Motherboard and graphics are OK, and you may want to change your Display only, If the secondary display behaves same, It will be a Hardware problem... you may have go to service center..
Please rate me if it is valuable, Thank you
Aug 28, 2011 | Compaq Presario 700 470024-192 Notebook
My compaq presario cq62-238dx felloff my hands, no scratches or damages are visible, when I first turned it on it worked as if nothing would have happenned, but later on the screen turned pink, the next...
I suggest you start diagnosing by using an external monitor, if available.
A VGA monitor.
(It can be a VGA monitor that looks like a small TV, {CRT}, or an LCD flat screen that has a VGA cable attached.
More information on VGA connectors,
Laptop off, and VGA monitor off, connect the VGA cable of the monitor to the Left side of the laptop.
(Rear top port)
Turn the monitor on, and then the laptop.
Do you see a display on the external monitor? (VGA monitor)
Press, and hold down on the Fn key (Function Key), and tap once on the F4 key.
A) If BOTH the external monitor screen, and the laptop screen have the same pinkish display, the problem is the graphics chip. (More on graphics chip in a moment)
B) If just the laptop screen is pinkish, and the external monitor graphics are okay, the problem is inside the laptop display.
1) Could be a loose connection of the Display Panel Cable.
{The Display Panel Cable attaches to the motherboard, and the LCD screen in the laptop display}
2) Could be a bad Display Panel Cable.
Possible damage to the Display Panel Cable is the the laptop display was open.
Look for signs of damage to the sheath of the Display Panel cable.
However the damage may not be apparent. The Display Panel Cable could have been stretched.
(Laptop display open when dropped)
The tiny wires inside the Display Panel Cable could have become damaged.
Testing requires that the Display Panel Cable be removed.
A multimeter is used to check continuity of each wire.
{Multimeter function knob is set to Ohms. 1K or 10K if these settings are available.
The Positive probe lead (Red) is touched to a wire at one end of the Display Panel Cable.
The Negative probe lead (Black) is touched to the other end of the wire.
Analog multimeter needle swings up, you have continuity. Don't worry about the Ohm reading at this point. As long as the needle moves.
No movement? Have a helper gently move the Display Panel Cable around.
See if there is continuity shown, or is intermittently shown.
Indicates a break in the wire.
Solution is to replace the Display Panel Cable.
Same with a digital multimeter. No reading, or intermittent reading indicates a broken wire.
Display Cable Kit - HP Part Number 595196-001
I have seen several listings on the internet.
3) Could be a bad LCD screen.
Check the connections.
Check the display panel cable
If this checks out okay suspect the LCD screen.
Compaq Presario CQ62-238dx Notebook PC - Service Manual,
(Free from HP Support),
Left-click on -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC - Maintenance and Service Guide
This is a PDF file. (The computer you are using now has Adobe Reader on it, which uses PDF files)
It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
In the Bookmarks menu on the left, click on the + sign to the left of Removal and replacement procedures.
Now click on the + sign to the left of Preliminary replacement requirements, then go on to Component replacement procedures
For additional questions post in a Comment.
Aug 19, 2011 | Compaq Presario CQ62238DX Laptop
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
Periodically the screen is captured by horizontal lines completely across the screen. Cannot access programs or even shut down properly. Any suggestions. Presario 700 laptop using Windows Vista. Thanks
This issue is due to the malfunctioning of the screen or due to any other internal hardware malfunctioning of the notebook.
To further isolate the issue, I request you to connect the external monitor and check.
Once after connecting the external monitor, please tsp Fn+F3 Switch between the display and external monitor in the following order:
External monitor
Display and external monitor
If the external display is fine then the issue either could be due the malfunctioning of the display cable connector between the screen of the notebook and motherboard or due to the malfunctioning of the screen.
As this the hardware issue, Please contact the nearest repair center to get it resolved.
May 29, 2010 | Compaq Presario 700 470024-192 Notebook
Facing Problem with compac v3000 no display
First see if any monitor will work, plugged in at back? If works, check, just isn't been LCD monitor has been disabled by a key command, then if NOT work, it is probably Video card. OR actual LCD, OR the LCD power supply and/or Inverter? may also be bad connection to MB? Or Broken ribbon in lid, or case. Faulty sleep open/close LCD switch? Try those.
Mar 02, 2010 | Compaq Presario 2580US Notebook
No monitor display on my laptop notebook
Aug 18, 2009 | Compaq Presario Notebook
Display went from extremely dark to complely black
Hello there.
I understand that your Notebook is not showing the display lights. To isolate the issue please do the following troubleshooting steps.
1) Check the display with external monitor. If the external monitor is showing the display then the problem is with the LCD screen. If the external monitor is not showing the display then the problem is with the display card.
2) If you have any torch light or a cell phone , try focusing the light on the LCD screen after the Notebook is powered on and check whether you are able to see the texts and images on the LCD. If you are able to see the images and texts then it is the problem of the LCD back-lights. The lights which glow at the back of the LCD panel are not working.
If your Notebook is under warranty HP will repair it free of cost.
Contact HP customer chat center for more information regarding the details of the repair and the procedure for sending the Notebook to HP in case of repair.
For contacting HP chat support click on this link or copy and paste it in address bar of a web browser.
Feb 17, 2009 | HP Compaq Presario M2010US Notebook
Presario V2000 screen goes white
This does sound like the cable, but it could also be the inverter. Here's a step by step to removing the screen.,compaq,step5.shtml
Jul 26, 2008 | HP Business Notebook NX9110 Notebook
Proview 19inch LCD MA982k model 900p
You are on the right track. Sometimes the ribbon cables will look fine but the wire inside the insulation is broken and will result in intermittant problems. Definately check the cable first and repair or replace. It is best to meter the cable while not connected to avoid false readings through other components. Should be a relatively easy repair.
Jan 03, 2008 | Proview PL926WBi 19" LCD Monitor
Compaq Presario 12XL125 Notebook Logo
170 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
