Question about Creative Labs Zen Touch MP3 Player
Hard disk prob
Hi.. it was stuck on hard disk problem.. now its on recovery mode and i pressed clean up. and its now stuck onscann dish.. please help !!!!
  • 1 more comment
  • natemort Dec 06, 2007
    I have the same problem and I don't have my music backed up! :(
    When I click on "format hard drive", it says "hard disk" error. I think that means my zen in broken! :(
  • fogo Dec 08, 2007
    were do i go to get new firmware for my zen touch..??
    President:
  • 4,402 Answers
Hard disk is bad.
can you format?
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Posted on Dec 06, 2007
  • Cary Farah
    Cary Farah Dec 08, 2007
    yep hard drive bad
Mac book air 13" i stuck on the startup. It does not go beyond the apple and the circle going around and around. Please help
Reboot your Mac with Command-R held down to see whether it can boot into Recovery Mode and if so, follow Apple's instructions for using Disk Utility to diagnose your hard drive. If it can't boot into Recovery Mode, take it in to an authorized Apple repair shop.
Aug 21, 2013 | Computers & Internet
I HAVE A SONY DIGITAL CAMERA DSC T-20 AND HAVING AN ERROR MESSAGE E:61:10 PLEASE SEND ME HOW I CAN SOLVE THIS PROB LEM
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
I hope it will be Helpful for you.
Thanks and keep Using FixYa
Mar 16, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
Why is my laptop is stuck in start up mode. solution 1 did not work, the screen i come to has 2 options launch repair and start normally, the launch repair does not work but the start normally option is...
Hi you should keep on tapping F8 while booting so that an option will appear to select safe mode. or if you have a recovery CD restart the computer then press F2 or Delete to access the Bios Page look for Boot Options and change the first boot priority to your CDROM restart the computer and just follow the instruction on the recovery disk.
Thanks for using Fixya.
Feb 05, 2011 | Acer Aspire 5920-6335 Laptop
Iphone is stuck!! Please Help!!!!
First make a hard reset ...do to that press home button and power button the same time until the phone restarts after restart press and hold quickly only the home button to go into the recovery mode then connect it to itunes and make the restore ;)
Dec 23, 2009 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Not recognized
Th prob lem could be most probably your hard drive casing not supplying the correct voltage and not enough for the hard disk to spin the moter so please connect the hd directly to the computer if its fine just change the external casing..
good luck
Jan 04, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Many problems-dirty disk?,PCI comm. controller problem, NVIDIA problems, freezing up-must use CTRL=ALT=Delete-to unfreeze. my hard drive is partitioned with the letter "D:"=Recovery-but for some...
When you boot, press F8 to reach the windows menu and select Safe mode. Clean and Defrag the disk. Go in the Device Manager and erase the entries under Graphic-Controller. Then reboot.
Sep 11, 2008 | Gateway Computers & Internet
Stuck in recovery mode, firmware problem
i have the same problem of recovery mode. can you help me please
Jul 12, 2008 | Creative Labs ZEN V Plus MP3 Player
Hi, I just bought a laptop brand new 4 days ago, it is a Hp Compaq Presario V3000 a couple days in, I believe a virus went on it, and now whenever I On my Laptop it comes up with the screen Choose start...
Restore the PC to original condition with the HP Recovery Manager Follow the steps below to use HP Recovery Manager to return your notebook to its baseline factory condition, then allow the PC to run all the setup programs.
  1. Press the power button to turn on the PC, and press F11 on the keyboard immediately while the computer is starting up. The HP Backup and Recovery Manager window will appear.
  2. Click Advanced options , select the System recovery option, and then click Next .
  3. If the Recovery Manager can access the hard drive it displays a prompt to backup up user files before continuing the recovery. You may either backup your files, or skip the backup and recover the operating system.
  4. If the Recovery Manager cannot access the hard drive to fix the system errors, use the set of Recovery disks that you created to recover the hard drive to its original condition.
After the hard drive is returned to its original condition, restart the PC and allow the PC to run all the setup programs. if thias does not work then you should return it to supplier
Jul 06, 2008 | Computers & Internet
Won't boot even after restore
Looks like you did as much as you could. Only thing left would be to do a fresh install. Let me know how you make out.
Chris
May 29, 2008 | Dell Dimension 2350 PC Desktop
Credit card size zen
Hi Lil
Sounds like you have tried all the obvious. The unit may have a terminal hardware problem or an unrecoverable firmware problem. I suggest that you return the unit to a dealer and see if there support guys can produce a cure for you. I am looking for any other things that you may try. Will post any for you soon
regards
Graeme
Feb 17, 2008 | Creative Labs Zen Digital Media Player
Creative Labs Zen Touch MP3 Player Logo
181 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
