Question about Nikon D1X Digital Camera
Washed out pictures
I can't seem to get a good quality picture from my D1X. The color seems to be washed out in my pictures.It doesn't matter if I use a handheld or in camera meter I still get washed out pictures. When I use a flash it's even worst. Could there be something wrong with my ccd sensor?
  • 58 Answers
I would check to see if you have set the exposure compensation and/or flash compensation to a high setting and forgot to put it back to zero.
Good luck.
Posted on Dec 06, 2007
Picture quality deteriorated
Most like one of the scan drive boards is failing. It would need troubleshooting to determine which board is weak.
Apr 17, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
Why is my picture
Since you do not supply information (type, brand, model, age)
about your set, it is difficult to guess at your problem. The settings are there (contrast, brightness, color) for you to readjust the set as it ages and are not often used past the setup stage when you get a new set.
Gamma is the base level to set the black part of the signal.
I do not know what lamp you would have in a TV set.
Jul 04, 2017 | Televison & Video
Colors on my TV seem to be washed out. Convergence is adjusted OK, brightness/color/tint settings don't seem to make a difference. I seem to have bright halos around all light colored images.
The fluid in the picture tubes needs replaced. It is a job for a professional. It usually costs about $250.00 for the job. You might say it's like giving your set an oil change.
Apr 09, 2011 | Philips 50P8341 50" Rear Projection...
My Sony wega triniton KV32FV27 has washed out color, low contrast/brightness. it was recently in the shop where they"rejuvenated the tube" and "adjusted the screendrives and focus". It...
The picture tube emission is dropping causing the picture to become washed out, the rejuvenating process removes build up of crud from the guns exposing more emission material, this improves quality in the overall picture. But since the picture tube was done a week ago it suggests the guns have been stripped of their remaining material and the picture tube will get progressively worse over time.
Feb 08, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
I have the same model. My picture is bad my white
If the pic seems dull and the colors are all washed out as well as the tint not being able to be ciorrected to correct tones. Its almost always caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit from the kit contains the coolant for all three CRT's and the CD with instructions.
Jul 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
Non-hd channels only. color is washed out with
try component cables and see if you get the same results.
Oct 24, 2009 | Panasonic Televison & Video
Pictures washed out
Washed out I would guess looks like it's all white or a lot of white instead of the colors on the pictures. My guess is that your camera is over-exposing the pictures. Usually keeping it in automatic should solve your problem. But if it still doesn't, then it might be that you have an offsetting function that I think is called EV, which is either a plus or a minus function. Plus for over-exposing and minus or under-exposing. Read the manual and look for this function. Usually keeping it on auto is enough. Let me know if this helps.
Jul 15, 2008 | Casio Exilim EX-S500 Digital Camera
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Open Questions:
Nikon D1X Digital Camera Logo
105 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
