When you plug usb mouse that works fine, but touchpad moves around the screen put doesnt click nor does left click at the bottom to bottons, at the bottom of the screen were you can see the synaptics pointing device the left click button is lit green??? anyone no what that means?
This probably means that the touch pad needs replacement or there is intermittent contact to the motherboard from the touch pad. If the laptop is under warranty the manufacturer will take care of this for you in that this is a manufacturing defect. Contact the manufacturer for support on this. Usually they will attempt to assist you fully.
Usually the green means that the button is pressed. Check the touch-pad buttons for dust or dirt. If they're clean, then probably need to be repaired.
