Question about JBL LC-S960 Car Speaker
6x9s in a clio
Hi i bought jbl 6x9s for my clio but having difficulty fitting them, already cut holes in parcel shelf to sit them in but cant find were to connect them and took half the car apart in frustration lol
  • 143 Answers
Forget it...
buy some speaker cable & run them from the head unit to the boot.
from the back of the stereo connect as follows:
Rear Left
green + to Big Spade on speaker
green/black - to Small Spade on speaker
Rear Right
purple + to Big Spade on speaker
purple/black - to Small Spade on speaker
Posted on Dec 17, 2007
Battery was flat this morning as I hadn't driven it in a week. Local garage just charged up the battery for me and now my roof refuses to open!
there are two latches in the boot that must be closed. You unlatch them to lift the parcel shelf.
the parcel shelf in the back has to be all the way down. There are two switches it sits on, that have to be activated before the top will go down.
the panel wasn't properly positioned so the roof would not open
Jun 02, 2016 | 2009 Mini Cooper Convertible
How do you remove rear speaker covers in a 96 geo
are they fitted in the rear doors or the parcel shelf ,if there aree no visable screws to un do if door fitted then will have to remove the door panel , if on parcel shelf same thing if no screws visable then remove from underneath , hope this is of some help
Sep 29, 2014 | 1996 Geo Prizm
How do i open Jaguar x-ype boot from inside.
It is possible to open from the inside, but causes a little bit of (hidden) cosmetic damage, so only do this if you have to get the boot open because it is completely jammed shut.
Remove the headrest from one of the sides of the back seat. I used the side where the smaller part opens when folding the seats down, but I would suggest you use the other side as once you get the seat down you have a bigger opening to let you get the other side down too.
The parcel shelf is in 3 parts, a wide centre part and 2 small endpieces which carry the slots for the seatbelts. Once the headrest is removed, insert a screwdriver into the join between the end-piece and the center part of the shelf, and lever the end-piece up an inch or so, grasp it and pull it up enough that a couple of clips disengage. Then, you will see that the centre part is now a loose fit. Next, using a sharp knife, a Stanley knife or similar, cut the centre shelf from the outside edge towards the middle, for about 30cm. Make this cut as far down at the back of the seat, and when you put it back and the headrest is reinstalled it will be invisible (well, almost)...the neater the cut, the less likely it will be seen afterwards.
Next, peel the centre shelf towards you, away from the rear window, until you can see a hole in the metal sub-shelf below. Ignore the two round central holes with cloth covering, but go for the elliptical hole near the side of the shelf.
Remember what the seat-back release cables look like in the boot? Held up with clips either side, the cables have a ribbed rubber sheath. Stick your hand in the hole into the boot and locate the cable. It will not be possible to unlock the seat release because the knob is out of reach (unless you have VERY long, bendy arms) but the clips are nt very secure, so just grasp the cable wherevr you can and pull hard to diislodge the clip. The cable will come away from its retaining clip, or actually, the clip will pull out of its housing and then you can simply fish the end out and release the seat-back.
Next, reach in and yank the other cable out too, or, if you can release the other seat-back easily in the normal way that would be better!
Now you can crawl into the boot.
With a screwdriver, remove the plastic cover that covers the boot-lock mechanism. A good torch is handy here! The 2 visible screws come out ok, but you will probably have to yank the cover off since you cant get at the bottom edge to ease it over the lock. Don't worry, it will split open, and can be popped back on later with no difficulty, just a small split in the plastic.
Finally, looking at the exposed lock, you will see a little lever with a hole in it, on the left hand side as you face the back of the car. Simply flick this up with your finger and the boot will open.
OK, it sounds complicated, but actually it took me just 20 minutes, 10 of which were used up trying to decide whether or not to cut the parcel shelf!
My mechanic has now fixed the problem so my boot opens as normal now, but I don't know what he did yet as he has gone on holiday and didn't tell me what had gone wrong, but it was certainly an electrical problem. However, his list of parts used lists only wire and terminals, so I don't think the solenoid was broken, just not getting power.
Anyway, until you get it fixed, just leave one of the rear seats unlocked, and you can crawl in and open the boot anytime.
Hope this helps! Colin
Nov 09, 2010 | 2005 Jaguar X-Type
How do i get the back parcel shelf out of my bmw 530d so i can tint the rear window? and also the back seats to get the parcel shelf out ?
Why do you need to remove the parcel shelf and the seats just to tint the window?
If you are using film tint lay it on the outside of the window cut it a little larger than you need it. Clean the inside rear window then use a squirt bottle with soapy water in it spray the window roll out you tint using a squeegee to remove air pockets. Finally trim the edge with a razor blade window tinted.
Aug 31, 2009 | 2002 BMW 5 Series
Hi,need to install 6x9 spreakers to my bmw e36 coupe rear shelf but see no other way to do it unless cut some metal off.May be there are ways to do it without any modifications?
You can make some plates from mdf or the like to "lift" the 6x9's up (can also be bought, but I can't remember were I bought mine from, was a while ago). just cut some mdf to take the speaker and cut about 1" around, paint or cover with material and screw through to the shelf.
Jul 05, 2009 | JBL GTO937 Car Speaker
Removing standard stereo?? How??
If the existing stereo is a double din, there will likely be screws to remove to get it out on a bracket. Depending on the make and model of the vehicle, there will be more or less to take apart to get it out. There is usually a way to get at the stereo without taking the whole dash apart. Look for seams in the near vicinity of the stereo. There may be screws or pop-clamps/fasteners or both. Screws are usually shielded from view by being installed under a piece of the dash that is merely pinch clamped on (can be carefully pried off - best to use a screwdriver tip wrapped in several layers of paper folded over it or a towel, or your fingers) If screws were used to fasten on the first piece of facing they may be accessible under ash tray or compartment drawer covers, tilting portions of heater/ac registers (some Toyota Tundras, and Sequoias are like this), or just fastened in a slant down position that you cant see from normal sitting position (try looking at the surrounding dash from down close to the seats). There may be a couple of pieces of the dash to remove to get to it. Do some more close looking around and see if any of these tips help.
May 03, 2009 | Car Audio & Video
Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
May 02, 2009 | GMC Jimmy Cars & Trucks
Speaker installment
I would run a 250-500 watt 2 channel high input capable amp.  run the original wires to the orginal speakers and jump off the original wires to the amp to push the secondary 6X9's you have.  So my understanding is.  you want the 4 original speakers and subs and add 2 additional speakers making 6 speakers not uncluding subs..
Head units care barely push 4 decent normal size speaker.  Usually they are 30-55watt per channel.  If you have 2 non sub speakers that are 250 watt max.. that's 500 total but don't push the amp all the way...start with it at 1/4 and listen to your stereo at a higher than nominal volume slowly turning up the amp.
James Mac
Sep 09, 2008 | JBL LC-S960 Car Speaker
6 by 9s
you will have to make a 6x9 templet and them you will have to cut it out.
Jun 20, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
JBL LC-S960 Car Speaker Logo
380 people viewed this question
Top JBL Car Audio & Video Experts
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
