Question about IBM ThinkPad T21 Notebook
Pccard connect card option vodafone
I bought a connect card by vodafone manufactor " option express card 7.2"
it uses hsxpa driver IN XP
but system recognized only the adapter and never the express card option
i have downloaded last driver 9.2 of this card but with not any success , card don't works and not recognized
well i try to ask u if u can help me
t21 - xp2 - 516 mb bios last ibm
thanks franco italy emanu.s@tiscali.it
  • sukabyte Jan 07, 2008
    hi mat,
    but this card it's not an hard driver c d etc
    it's an express card that use pcmcia adaptor
    so i have putted in pcmcia the adaptor for thinkpad t21 but in management i can see any active modem modafone
    the adaptor ( express to pcmcia )work ! infact it build 3 usb port and two port named hsxpa ... but when i put in the hole of adaptor the express card VODAFONE BY OPTON express card 7.2
    Don't work his led blue remain still fix don't blinked
    this express card should be at works it will build other port
    as modem umts or gsm ... net ecc
    thank u for ur time
    Franco
  • sukabyte Jun 18, 2008
    well i'm Franco from italy www.myspace.com/biofunk
    i resolve all problem in this way ( ibm t21 pentium3)
    work fine !!!
    1) format all hd system (or delete all xp original driver usb and hub in system32 of windows)
    2) ( check port usb in manager they must be yellow)
    4) put option express card 7.2 whole with adapter in pcmcia
    (the card begin flashing red and blue)
    4) don't reboot the system , wait that manager seeks driver of it
    5) this is a sign that card is recognized as periferic
    5)put vodafone cd in exe
    6) it will seeks the card (say no ), ok ,ok , create new profile then don't reboot ur pc . try to do a connection by his program
    7) manager will checks other driver then automaticly get all rest of driver by his cd
    8) retry to do a connection
    9) gprs or umts
    10) don't reboot your sistem
    11) remove the card and wait 10 sec , reput the whole card it will go in flash red or blue
    12 )now u have tested that ur card work fine
    13 ) reboot the system and put ur card
    I found this solve after one undred tried and now it work fine
    ( but vodafone is very expansive :( )
    problem borns cause before windows puts his generic driver !!!
    as usb and hsxpa
    Ciao e Forza Italia
No dear helper card needs more than 500ma ( i think ) so the problem persist!!!
awaiting a best solution
Posted on Mar 25, 2008
For the sake of completeness: I have the same problem with the same card, although I have a FSC Lifebook S4542 running Win2K SP4. The converter is identified as a USB host adapter but the card is not detected, not even as an "unknown device" or a device for which no driver is present. The blue light on the card is on solid.
BTW: An Option GTmax (which is a native CardBus device) works fine in the same laptop and with the same SIM.
I then did a cross test, inserting the converter and card into an IBM T41 running XP SP2. Here, after Windows has detected the converter and installed the drivers for it, another device - the data card - is identified. (Windows fails to find a driver for it, though, as I had not preinstalled the software). Device Manager reports that the card draws 500 mA from its USB hub (i.e. the converter), which is the maximum amount which can be supplied on a single port. With the amount the converter needs for itself, this adds up to more than 500 mA which the converter would draw from the CardBus socket. If a particular model of laptop cannot provide that much, problems would arise.
Another possible reason is a driver issue, i.e. the driver that Windows auto-selects installs for the converter does not report any errors, even though it is unsuitable for the converter or faulty and thus will never report any devices. (I remember having a similar issue with CompactFlash memory cards on some PC Card controllers - Windows would fail to access the data on the card unless I manually selected a different driver for the card, which identified itself as an IDE controller with a disk attached).
That's as far as I got... any further input that will take us to the point at which the card works as it should would be greatly appreciated.
Posted on Mar 20, 2008
Sorry but it's not an hard drive that don't work in
but it's a pcmcia .
so i need that port pcmcia should be recognize my card VODAFONE
when i put in pcmcia the adaptor it works ( only adaptor)
but the card VODAFONE UMTS don't work
it's not recognized by pc ...
also his modem and other ports ( that it must do )
i can't see in managent board any card ...no conflict ecc
for my pc it don't exist but adaptor (express to pcmcia )
was recognised
thank u for ur time
Posted on Jan 07, 2008
    Sergeant:
  • 263 Answers
Some times the computer can not give the drive letter to asigne automatically like D:/ or E:/ or your computer does not support that usb driver ok you can make manual changes or detection just go to control panel, administrative tools, computer manager, storage , disk management, and you'll see on the right side at the top all the devices that they are recognized by the computer and at the battom you'll see all the devices plus the one does not have a letter assigned click on the one has no letter or it seds unrecognized with the right botton mouse so you'll see the list of options do format and change driver letter path check it and assigne the letter to be recognized by the system
Posted on Dec 30, 2007
No video after boot up
Ahem.
Driver: Small piece of software that allows the Operating System to communicate with a device.
The device in question is the graphics chipset.
The Operating System is now Windows 7 64-bit.
You were running Windows XP -> 32bit
(Have you got audio? Sound)
This is why I repeatedly try to tell people;
LOOK TO SEE IF DRIVERS ARE AVAILABLE,
before trying to upgrade to frickin Windows 7!
http://support.asus.com/Download.aspx?SLanguage=en&m=M4A785TD-V+EVO&p=1&s=24
Yes sir; sure are.
+ VGA (3)
Suggest use the oldest version -
AMD VGA driver V8 631.0.0
http://en.wikipedia.org/wiki/Integrated_circuit
The reason Windows XP blue screened is because the Integrated Graphics of the Asus M4A785TD-V motherboard couldn\'t handle the game.
You need a graphics card. A PCI Express graphics card inserted into the BLUE PCI Express x16 expansion slot, on the motherboard.
(Remember; Install the software F-I-R-S-T, then unplug from power, FOLLOW Anti-Static Precautions; and THEN physically install the graphics card.
Software; The Installation Disk for the graphics card.
Has the Drivers, and user interface.
User Interface: Catalyst Control Center for ATI graphics cards;
Nvidia Control Center for Nvidia graphics cards)
Regards,
joecoolvette
Dec 25, 2012 | ASUS M4A785TD-V EVO Motherboard
I have Wolfdale 1333-D667 motherboard which Supports Dual Channel DDR2 667/533 memory. Can i upgrade it with a DDR3 Graphics card?
atlantisshak, you can use a graphics card with ANY graphics ram memory.
A graphics card has it's own Processor, and graphics memory.
Doesn't depend on the system resources, ( Processor and Ram Memory)
GPU = Graphics Processing Unit, the graphics card's processor,
http://en.wikipedia.org/wiki/GPU
Doesn't matter if you use a graphics card, that has GDDR3, or GDDR4, or GDDR5, graphics ram memory.
I do however, recommend using a PCI Express graphics card based on the 2.0 technology. (PCI Express 2.0), and NOT the PCI Express 2.1 technology.
Could have problems.
For additional questions please post in a Comment.
Regards,
joecoolvette
{ ALSO;
Make SURE you,
1) Windows running on the computer, install the graphics card's Installation Disk. (CD disk)
AFTER loading the graphics card's 'Control Panel', and drivers,
DO NOT RESTART.
Close all windows, go back to the desktop screen. Shut the computer down normally.
THEN unplug from power, AND follow Anti-Static Precautions.
Physically install the graphics card. Plug the monitor into the graphics card. Close the computer case.
Plug the computer into power. WAIT 1 minute, turn the computer on.
IF you do not, you stand the chance of driver conflict.
To explain;
When a device (Such as this graphics card), is installed on a computer, Windows 'break it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's
THOUSANDS of generic, one size fits all, drivers.
This = NO.
Could cause a driver conflict.
Windows: " Which drivers do I use? These or THESE?"
[ If you install the graphics card FIRST, THE drivers are NOT there.
Then you go back, and do install the drivers, there may be a driver conflict ]
Drivers:
Small pieces of software that allow the Operating System to communicate with a device.
Some O/S examples are Windows XP, Windows Vista, and Windows 7.
The graphics card is an example of a device.
[ When you put the Installation Disk in the optical drive's tray, and close it, the graphics card's software will come up. Go for the option with the 'Control Panel', AND drivers.
Example; For an ATI Radeon graphics card, the 'Control Panel' is ATI Cataylst Control Center ]
Jun 18, 2012 | Computers & Internet
I am upgrading to windows 7 where can i find the driver for the 1784 pcmk series b
Here is information regarding using the card with Windows 7 32-bit. It discribes how the card cannot be used with Windows 7 64-bit.
http://centriasupport.custhelp.com/app/answers/detail/a_id/117503/~/1784-pcmk-series-a-or-b-card-in-a-windows-7-operating-system
Here is the driver:
http://www.rockwellautomation.com/support/pccards/get/1784-PCMK_Win2k_XP.zip
May 26, 2011 | Allen-Bradley Company, Inc. Computers &...
After installong fx5500 drivers the card stops to work and hardware resource conflicting problem occurs
Please unistall whatever drivers you may have installed for the video card
Restart the PC
Download and install the driver from here: DRIVER
Install the driver
Restart the PC
Mar 06, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Black Screen after installing new NVidia 9400GT
Put the old card back in, remove the old drivers and restart it in VGA mode.
You don't say what operating system you use, but XP & Vista you should be able to hit F8 before the windows splash screen to select VGA mode or Safe Mode.
Once you do that you should be able to put the new card in and start it in standard VGA mode then load the new drivers.
May 25, 2010 | SPARKLE Computer Sparkle GeForce 8500 GT /...
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
When i install the card and load the display drivers, all i get is 4bit at 640 by 480 pixels??
vmaurel30, it sounds like the wrong drivers are being loaded.
It would be very helpful is we knew what type of operating system you are using, but here is the best place to get drivers:
Windows XP/Vista/7 32bit:
http://www.nvidia.com/object/winxp_178.24_whql.html
Oct 27, 2009 | MSI NX8400GS-TD512EH, PCI Express Video...
Express card and TV tuner not working
Reinstall the drivers, just put the driver CD given along with the card, and autorun. OS will automatically list the available drivers and select driver for windows xp or vista and give OK. That's all.and make sure that your vista or 7 rc is set to signal area .like australia india
Jun 24, 2009 | Acer Aspire 8920-6671 Notebook
IBM ThinkPad T21 Notebook Logo
298 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
