Question about Toshiba 20AF41 20" TV
Chanel will not go up or down.
It program all the chanels, after i hit the enter button. the chanels only
went ch. 2, to ch.13. what am i doing wrong. I need a code..George
  • 232 Answers
Re: chanel will not go up or down.
George, your tv`s tuning system is set to "air", (roof top antenna) you need to go into your menu and change it to "cable", then do "autoprogram" again and it will add the channels above 13. You really should order the original remote for yourself, you can probably get one here; Good Luck and Happy Holidays
Posted on Dec 05, 2007
0 characters
3 Points
How do i add chanels
In the menu with auto program OR direct enter channels with the remote and in the menu manually add them one at a time(most sets have a add or delete feature in menu for single channels).
May 16, 2012 | Sampo SME-32DL5 32" TV
My tv phillips model prf227 s325 i have problemdont see chanels after 65ithin that ist in mode hotel.....and dont have remote controli have an universal phillis
type in the code 319753 followed IMMEDIATELY by the MUTE button. The number sequence and mute button must be done within 20 seconds of each other. Once you hit mute a new menu will appeal click on CHANNEL INPUT (should be the third one down) then a new menu will come up and click AUTO PROGRAM at the bottom, this will go through all the channels (up too I think 90?) and unlock them one by one.
Jun 13, 2010 | Standard (CRT) Televisions
Don't know how to change from cable to antenna
on the back of your set
there may be a small switch someone with 2 or 3 different options
Jan 20, 2009 | Sony KV-24FV12 24" TV
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
GE 46in Guide Plus Gemstar tv
I have sound from dvd player but no sound when I have just tv on
Nov 06, 2008 | Standard (CRT) Televisions
No voice on some chanels and some chanel get voice mixmemorax
check to see if the sap feature is on. [ this is to listen to a program in another language. disable the feature either with your remote or on the tv, in the menu section or a sap button.
good luck.
Feb 15, 2008 | Standard (CRT) Televisions
Lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
Toshiba 20AF41 20" TV Logo
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
