Lack of power to a terrabyte WD external hard drive
No lights on the hard drive, but light on the transformer. Any ideas?
Thanks,
RR
  • HanaHawk Dec 04, 2007
    SeaJade,
    As it turned out, I needed to disconnect the plug from the wall, and the firewire connections from the hard drive. (support was provided by WD ) The evidently reset the drive, all is peaceful and serene once more. Thanks so much for a lightning fast answer.
    Best,
    RR
    Scholar:
  • 104 Answers
Hi, mmm that's a curly one....possibly a faulty cable from the transformer to the drive or faulty connection. How does it connect to the drive itself? Does it have pins? If so maybe one is bent.
I am assuming that the transformer is the one that came with the drive also, else the voltage may be wrong.
Does the drive have like a lock mechanism like for transportation?
Also if it's new or under warranty returning it for replacement might be an option too.
Let us know how you go and if we can help further or if you get anymore information.
SeaJade
Posted on Dec 04, 2007
Power switch not working
is this a transformer power supply? if so get a volt meter and check output a power supply connector to see if it matches what is on the power supply as output voltage. good luck
May 19, 2010 | Western Digital 250GB MyBook External USB...
My hard drive is not working, but I think it may be the power source because the green light on the transformer only stays on briefly when I plug it in. How can I be sure if that is the problem?
If you look at the Power supply box there should be a green light. If you unplug the cord and plug it in again it might just blink then stay our.. it is a common problem with these WD Elements. If it is newer, then it is under warranty.
How to check the warranty on a WD drive or product
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=915&p_created=1047361575
Title: What would void the warranty on my drive?
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=916&p_created=1048294698
If not they will sell you another one.
A replacement or extra power supply for your external drive can be purchased from our phone support team by calling 1-800-275-4932. Any technical support representative will be able to sell this part. Please have the serial number or model number of the hard drive ready, as this is needed to determine the correct adaptor type for the hard drive.
I hope this helps,
Randy
FixYa Support Team
Jan 04, 2010 | Western Digital Elements powered by WD 320...
My WD external hard drive stopped working
wd external hard drive making ticking noise and seem to have lost all my photos and music
Dec 17, 2009 | Western Digital Computers & Internet
WD ELEMENT DOESNT POWER UP. GREEN AND BLUE LIGHT FLASHES
Have you contacted WDE.. by email,or, phone? Seems like that the hard drive has had its bios info corrupted , due to possibly hooking it up to the pc(in the wrong order), or even, a power surge that you were not aware of... The Manufacturer can send you a link to upgrade/restore the harddrive bios...
Sep 01, 2009 | Western Digital Elements powered by WD 320...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Mar 25, 2009 | Western Digital WD Passport 250GB Portable...
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different...
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
I have an wd 500gb external hard drive.it will not power up. i think it is the transformer does anybody know where i can get one or fix it?
With voltmeter, check voltage from the transformer if you think it is a power issue. If it is faulty, Radio Shack may have something with the right size connector and voltage. Ebay is another option. However be forewarned that MyBook by WD are known to blow up the drive controller board. My 500GB "World Edition" did so after 1.5 yrs. Drive spins but no access. Took controller board out and found burned chip pins.
Dec 08, 2008 | Western Digital 500GB My Book Pro-External...
Computers & Internet Logo
321 people viewed this question
Alun Cox
David Payne
David Payne
