Question about Photography
Sharper image desktop slide viewer SM425
Hello, I just inherited this unit and there is a knob on the left side that says to pull it all the way out when loading slides. It won't pull out and I am afraid I will break it. Do you know how this thing works? Thanks, Nancy
I don't know if it's the same unit I have, but if it is, when you pull out the bottom of the screen for viewing then the knob will pull out.
Posted on Dec 31, 2007
Yeah, take the thing back. it is junk.
Posted on Feb 23, 2009
How can I tell if a Sharper Image S1698 Air Purifier is working?
Turn it on high. Put a kleenex up to the intake or discharge screen. It will push it away or pull it towards the screen depending on if you are on the intake or discharge side of the unit.
Jan 21, 2015 | Sharper Image Air Purifiers
Sharper image manuals
where do I get the sharper image photo viewer manual
Jan 01, 2014 | Health & Beauty
I have a Sharper Image Power Tower 200 and I don't know where to plug in the power cord. Thank you.
On the same side were the turning knob is located, all the way down under the base there is a very subtle slot to plug in your cord.
Aug 13, 2011 | Sharper Image Power Tower Motorized DVD...
Well we bought this out of Avon and it wont turn on, so what do i do to get it on?
Slide the button on the Left, down (the screen facing you).
Then on the Left, hold down the top button for a few seconds until the unit turns on.
Oct 26, 2010 | Sharper Image 1612911 MP3 Player
Left side of my sharper image ct411 doesn't work at all.
Check your cable and make sure there aren't any frayed or cut wires. If your cable looks good, then open up your headphones and make sure the connection to each speaker is correctly soldered. Sometimes when you expand/contract the size setting on these headphones it pulls the wire until it eventually disconnects. I hope this helps!
Aug 31, 2010 | Sharper Image (CT411) Consumer Headphones
Uninstall Sharper Image Tie Rack from clothing rod
The tie rack just clips on in the middle. the small piece on the top of the bar in the middle of the rack slides to the left to uninstall, to the right to install. on the bottom middle of the rack is a round piece that tightens to hold the rack level. loosen that piece first, that the top middle piece should slide to the left.
Dec 30, 2009 | Kitchen Appliances - Others
Cd cover doesn't open
Fiddled with it, looked at hinges to figure direction should open and pulled it slowly open. Button doesn't work but I can open/close unit. Just flips up from the front edge, doens't slide back or anything.
May 13, 2009 | Sharper Image GM402 CD Shelf System
Problems Loading Photos To Digital Photo KeyChain
hi there I got a new treo palm and i mix my finger in i dont know button an i lost my main screen and i got on screen horizontal lines side to side where it indicates ( Sprint , Quick Tour , Non Unread Masegges, No uncoming apoinments ) And the space live search bar ) how can i get out of this just the comands thank you very much.
Jan 06, 2009 | Computers & Internet
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Photography Logo
472 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
