Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Model KV 20M20
This tv had earphones plugged into the earphone jack in the front of the set. Now they have been removed, the tv has no sound. When I push the volume hi/lo selector on the front of the tv, it changes the channel. Would the sound have had to been turned off in order for the earphones to work?
  • 43 Answers
You may have a bad H board which is the board that has the voulme/channel buttons on it. You may want to have a Sony asc give you an estimate to repair. Good Luck
Posted on Jan 23, 2008
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
Where is Earphone area on Prima model cv2011 tv/dvd set
I'm sorry to say but this model of TV doesn't not have any headphone jacks.
May 02, 2008 | Prima CV2011 TV
Describe your FD Trinitron WEGA KV-32FS120 32" TV Problem i have a sony trinitron kv32fx68e and all of a sudden it wouldnt turn on. the red standby light just keeps flashishing. what could be the...
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Aug 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Does Sony FD Trinitron WEGA KV-21CL10 21" TV has a headphone jack?
Yes it does have a headphone jack. Lift the plastic door at bottom front center of TV to expose jack.
Aug 15, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
How to set the channels on a Sony KV-20M20 TV without the remote
Buy a universal remote at WalMart for $10 and set the code to your TV according to the chart that comes with the remote. Most functions of your original remote should work if the code is correct. Sony - TV - try all listed codes on the chart, one of them should be able to control the TV. Check at local thrift store (Goodwill). You just may find a Sony remote there or possibly order one online from remotes.com
Aug 12, 2010 | Sony KV-20M20 20" TV
What ports does a sony trinitron tv have?
sony trinitron is a very old model CRT television and will most likely not have even the red/white/yellow jacks. It will have an antenna jack, and a earphone socket.
Jan 20, 2010 | HP Pavilion dv6000z Notebook
Sony Trinitron, KV-20M20, cannot access most cable TV channels??
It may be that the tuner is bad. It works in bands and can lose upper bands. If you use a top of set box for cable it may need reset.
Mar 13, 2009 | Sony KV-20M20 20" TV
No sound through speakers, but ok through headset
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
Jan 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
110 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
