Question about Philips FWC1 CD Shelf System
3-Cd player part
Having troble playing any disk in any socket. Display says no disk
  • 8,596 Answers
Unplug/replug the system, then run a cd cleaner
Posted on Apr 08, 2008
What is wrong with my CD player?
Great player. Although the manual does not say a thing about this error, I'll try.
I think you use normal CD's and not disks you or someone burned for you.
The only thing I can think of is the CD must be dirty to scratched.
Or if you try to play disks, burned in a PC, that could cause trouble too. Although all CD and DVD burners in a PC, can play these disks, not all CD players can. Only the ones where the manufacturer says the drive is compatible with CD-R and or CD-RW.
A normal CD has metal as a reflector and gives a clear image from the ones and zeros on the disk. CD-R and CD-RV only have a dye on which a laser has changed the colour. Not giving a clear distinction between ones and zeros. The better CD players, have a stable motor and so on, but the laser is not set up for the dye disks. And although sometimes a disk can be played, for the player it looks lie a "dirty" disk.
I hope this helps.
If not, perhaps you should clean the laser, with a special cleaning disk. DONT open the player and DONT touch the laser.
Jul 25, 2014 | Cambridge Audio Azur 840C CD Player
I am having issues after I burn a cd it is not playing in a CD-R capable car cd player. It also wont play DVDs on my computer. I have a Dell Studio
make sure the burner's setting to "close" the disk is set to the yes or on position. that will close and standardize the disk for maximum compatibility with other players
Sep 07, 2010 | Dell Computers & Internet
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
I have a wurltzer CD 100 disk player. I think the
Either the CD player, CD control unit, or Selection & Credit Computer are defective. I can help over the phone with troubleshooting, please email tech@wurlitzer-ohio.com.
Jul 30, 2010 | Wurlitzer Jukebox CD Player
Every time u play multi cd player message comes reading and take long time to play
lens is dirty and having trouble reading the disks. get a lens cleaner disk from any electronics store.
Jan 14, 2010 | Bose Wave music system Multi-CD Changer...
CD stopped playing in middle of disk. Will not
It is likely that the cable has become disconnected from the disk changer in the trunk.
Examine the changer (With the car turned off) there could be several cables connected to it. Check them to be sure that they are properly connected.
This is a common problem for people who use their trunk, since items can move around and knock the cables out of their sockets.
Good Luck!
Jan 02, 2010 | Car Audio & Video
2001 Lexus LS430 6 Disk CD Player ''CD ERROR''
The sixth place is where the cd that was being played has to be put before it can take another cd to play. there should be a reset button some where im not sure where yet but I will find out and let you know shortly.
Aug 27, 2009 | Car Audio & Video
DVD player in 05 Nissan Quest will play a DVD then quit
Did it come back on later? Did you try a different DVD ? Cars are a harsh inviroment as cars get parked in the sun and left out in the cold and tend to change interior temps very quickly and condensation can build up rust and fogg up things. Did you try running a CD cleaner disk? Can you hear the disk turning as the DVD or cleaner disk is in there ? Do the function buttons light up? If its plum dead no sounds no ejeck it could have blown a fuse. If it seems to be going but not making a picture or auitio sound and the cleaner disk or other disk is no help the bulb may have gone out. In the dark with a clear disk CD or DVD doesnt matter in it you should see some light coming out where the disk goes. If not the bulb may have gone out Call the geek squad at curcuit city and tell them what you find and they'll tell you the troble your in cheapest.
Aug 13, 2009 | TMI Products VizuaLogic...
Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Sep 08, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Nakamichi cd45z
The CD45z does not play MP3's ....Nak is about SQ ...since MP3's are poor quality ...this doesn't fit with what Nak is about.
Mar 03, 2008 | Nakamichi CD-45Z CD Player
Philips FWC1 CD Shelf System Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
