Question about Zebra LP 2844 Thermal Printer
Zebra LP2844 on com1 long time before starts printing
I have downloaded and installed lastest drivers from Zebras site.
When in printer properties there is a button to print a test page.
When connected on lpt1 after pressing 'print test page' button it prints correct test label right away
When connected on com1 ie. serial port it prints correct test page and it prints it quickly when it prints it but from pressing button to starting to print the label there is a delay of about 45 seconds.
I also have a TLP2844 (same thing but uses a ribbon) and this does exactly the same thing.
I have tried a Citzen CLP521 on the same serial port - com1 and it works fine.
My Interlink parcel software does not see the printer either but may just be timing out ?
I have tried 2 different serial cables but no difference although neither were ones supplied with the machine.
Zebra customer support suggest upgrading the firmware - i have downloaded from the zebra website but it does not tell you have to upload it to the printer.
Any ideas ???
Kind regards - Scott
I have tried
  • Anonymous Mar 27, 2014
    Zebra ZT230s set up to print labels, however when not in use for a period of time (as little as 30 minutes) the printer will not print, but rather deletes anything put into the print que, including test pages.
  • 53 Answers
You need to increase the baud rate of the serial port on the printer and pc, the default baud rate of the serial port is 9600kbp which is heaps slower then the LPT port which can rate atleast 100 times faster.
the reason why it is taking 45sec before printing is because the pc is sending a lot of graphics data to the printer, this can be cause by two main things
1) you could be printing a lot of logos or graphics .
or
2) you are printing using a nonhardware font so the driver has to convert all of the text into graphics. you can fix this by selecting a hardware font (has a printer logo next to it's name in word). also outputting EPL (the printers native command language) would be extreamly quick.
you could also download ZebraDesigner which includes drivers.
i would also recommend not updating the firmware as it can do more harm then good, and if you make a mistake you kill the printer and it voids the warranty
best of luck
Posted on Dec 07, 2007
Hi Tyreman
i have the same problem and i' ve spent to much time on this problem without solving it.
Have you solved ?
I print just TEXT without any graphics, so i have not understood the solution of gr0b...How can i do ? Can you be more clear ?
I have also another problem...how can i set the lenght of the page to print ? For example, if i need to print only 3 lines, the page must be short, if i print 50 lines the page must be longer.
I use continuos paper without label.
I hope i was clear, thank you for your answer.
Posted on Feb 02, 2010
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
ZEBRA LP 2844 PRINTING PROBLEM IN USPS SHIPPING ASSISTANT
Are you sure that the page size is wrong, or are you just guessing because of the way that the label is printing? I would uninstall the driver - delete the printer from printers and faxes and remove the driver from Server Properties (in the file drop down in Printers and Faxes). Go to ups.zebra.com/ctp and get the latest driver - you have to have the UPS version of the driver in order to support pass-through printing. Go into your UPS Ship Asst application and make sure that the generic thermal is not checked.
Jan 15, 2010 | Zebra Eltron LP 2824 Thermal Printer
I have a Zebra LP2844 Thermal Printer from UPS. I
Welcome to the club. Been fighting this for almost a year. There is now a driver for vista available from Zebra to fix. I can now print 1 label from quick books. to print a second i have to restart computer and quick books. still searching for the answer.
Dec 08, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
My zebra lp2844 just wont print at all, it just feeds paper
when you start printing, nothing printed ???? maybe the problem at the printhead. make sure the printhead cable plugged to right socked on the mainboard
Jun 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
NEED THE DRIVERS FOR MODEL NO LP2844 ZEBRA
I have found that some times the zebra driver don't work well with Xp or Vista. Try these drivers :
http://www.seagullscientific.com/aspx/thermal_95.aspx
They have never let me down.
Dec 22, 2007 | Zebra LP 2844 Thermal Printer
Only every fourth label Prints
We've been having problems with ours. Make sure that the properties are correctly set, landscape, portrait, 180' rotation, label size, on the printer properties. Then check again through whatever package you are using 'printer properties' and try a print. You may have to re-enter properties each time you print.
Sep 01, 2006 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
1,634 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
