Question about ATI RADEON 9550 Graphic Card
9550 installed but dead screen.
Hi. I have a pent 4 (1.7 mhz) with a agp 4x slot currently with a geforce2 mx4000. I installed a radeon 9550 powered up and the fan worked but the moniter was dead. Replaced the card with my old one and it worked fine. Any ideas?
Thanks
  • mesmer Dec 05, 2007
    Thanks, could you expand on that (for the technically challanged) ?
    There no video options in my Bios. I have a NEC Powermate ML3. Bios is American Megatrends version 07.00T dated 04/02/2001. Thanks.
    Genius:
  • 1,601 Answers
Change the video options in the BIOS
Posted on Dec 05, 2007
Driver download
GeCube (GC-R9550GU-C3)
Model Radeon 9550 128MB 128-bit DDR AGP 4X/8X Video Card
Go to: http://support.amd.com/en-us/download
Setp 1: Desktop Graphics
Setp 2: Radeon 9xxx Series
Step 3: Radeon 9550 Series
Step 4: Select your operating system
Oct 18, 2013 | GeCube (GC-R9550GU-C3) Graphic Card
I am putting together an ASRock mobo. I am told NOT to use a 3.3v AGP card. as it will damage the board. ASRock K7S41 / K7S41GX. N Videa replys are not specific. I have 3 AGP video cards and have no idea...
Hi, you can download a manual here:
Your mainboard has AGP slot.
  • 1 slot for AGP 8X/4X 1.5V
  • http://www.asrock.com/mb/overview.asp?Model=K7S41GX
    http://www.nvidia.com/page/geforce2mx.html
    The to first one is AGP.
    The last one is PCI-E
    Graphics Processor: NVIDIA GeForce2 MX 200
    NVIDIA Model Number: 8859
    Memory: 64MB
    Outputs: DVI
    Interface / Slot Type: AGP
    • Installed Memory: 32
    • Interface Type: Video - 15 pin High-Density D-shell (VGA)
    • Video Chipset: NVIDIA GeForce2 MX400
    • Slot Type: AGP
    GeForce MX4000 Bus Type PCI Slot Memory on Board 64 MB DDR RAMDAC Support 270 MHz Max. Resolution 2048x1536 8/16/32 bit colors with 60Hz (Analog) Memory Interface 64-bit Display Output Dual VGA
    (1x On-Board VGA,
    1x MD9-pin port supports 1 x VGA) Operating System Support Windows® XP/2K/98//Me/NT 4.0
    Aug 28, 2011 | Asrock K7S41GX Motherboard
    CONNECT 3D RADEON 9550 256MB display problem
    That graphics card i'm afraid is not good for todays games, same thing goes for your pentium 4. A driver update may fix your problem but that card and cpu need changing, probably a new motherboard would be needed also to fit a pci express graphics card along with a core 2 duo processor.
    May 25, 2009 | ATI RADEON HD 2400 PRO Graphic Card
    Powercolor Radeon 9550 R96 256mb Card - Lights on, noone at home!
    Depends on the video card ,it might require more power ,200w is fine for onboard but add other components and the system needs more power.
    Disconnect the harddrive or CD ROM drive and see if the system will start.
    If it starts then you will need more power 300-400w at least but shuttle power supplies can be expensive to get.
    May 18, 2009 | Power Color RADEON 9550 R96-LC3 (128 MB)...
    Ati radeon 9550 agp with pinnacle pctv hd problem please help
    Try to put it on another pci slot. if you are using the one right under the agp, then that is your culprit.  the agp and the top pci slot share video resources.  just put it on another pci slot, if you have to swap another non-video related card to the one just beneath the agp slot.  Hope this helps.
    Mar 07, 2009 | ATI Radeon 8500 64MB AGP DVI/CRT/SVID...
    Video card
    The MSI KT4V motherboard is an AGP board supporting 4x/8x AGP. You cannot use a newer PCI-Express Video Card, however an Nvidia GeForce FX 5500 either PCI or AGP will run just fine in it. The NVidia FX 5500 doesn't come in PCI-E. Additionally The ATI Radeon 9550 doesn't come PCI-E so you should be safe with AGP versions of either. I should note however, that you'll get better performance out of the ATI Radeon 9550 as opposed to the NVidia FX 5500.
    I hope this answers your question,
    Analog Anomaly
    Dec 18, 2008 | MSI KT4V (MS-6712) Motherboard
    Graphic issue
    It sounds like the refrsh rate set in Windows is too high for your monitor, try going into safe mode and setting the refresh rate to 60Hz.
    Jun 26, 2008 | GE Asus V9400 /TD GeForce MX4000 64MB DDR...
    Intel P$ 1.8 mhz on a D845HV/D845WN board
    Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
    Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
    When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
    I hope this helped.
    Feb 20, 2008 | Intel Motherboard
    Grapics card
    Most current AGP video cards are now 8X and they will still work with your motherboard but will just be limited to 4X. Trying to find a 4X might be time consuming whereas using an 8X downgraded to 4x would be comparatively easier and faster.
    Additionally most Video cards will work under XP with the appropriate drivers but Vista has a limited list of compatible Video cards.
    Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
    Good luck and kind regards.
    Dec 08, 2007 | Nvidia GeForce2 MX200 64MB 4x AGP Graphic...
    ATI RADEON 9550 Graphic Card Logo
    67 people viewed this question
    Top ATI Computers & Internet Experts
    David
    David
    Computer Links
    Alun Cox
    Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
