REd background instead of black
I have a Panasonic PT-LC75U LCD projector. When I power it up the screen is red. When I go through the menu to the background it is saying that it is black but it is red. What would cause this to happen?
  • dwutter Dec 06, 2007
    Thank you for your help. Any idea where to go to get this fixed or how much it may cost? I purchased this on ebay under the description that it worked perfectly. The previous owner replaced the bulb recently so I took the bulb out and found that there is a square glass lense? that the bulb projects through right in front of the bulb, that is cracked. This lense has small square markings like a piece of graph paper. Could this be the problem?
    Thanks so much.
    Thank you for your help!
    President:
  • 3,130 Answers
It is low voltage in the screen driver board, probably a bad capacitor in the screen driver board or perhaps in the main power supply. The only way to tell would be to look at a schematic and measure the voltage and check the voltage source on the power supply board. If the voltage was low, replacing the board should fix your problem. If the voltage was normal at the power supply, then the screen driver board would need to be replaced. Good Luck
Posted on Dec 06, 2007
  • Larry  Dillon
    Larry Dillon Dec 06, 2007
    Yes this could be the problem. If asking for help, you really need to tell the entire story so we do not have to guess, My guess now is that since the glass is cracked, there is damage to the light engine. This would be considered shipping damage and you should check with the seller or the shipper about a damage report. A light engine for this unit will cost about 900 to 1000 bucks.
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
Panasonic PT LC76U Multimedia Projector Lamp how do i reset the timer
press the MENU button to display the menu screen, and then press the UP and DOWN aero button to select the "OPTION" menu. press the ENTER button and then press the UP and DOWN aero button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" screen will be displayed.
(NOTE: press any button other then the POWER button to cancel the "LAMP RUNTIME" screen)
Press the POWER button to turn off the power.
The POWER button on the projector illuminates red.
This will reset the cumulative usage time for the lamp unit to "0"
Jan 12, 2011 | Panasonic PT LC76U Multimedia Projector
I have Panasonic PT-LC75U bought in 2003, with 740hrs on my 2nd bulb. I have red vertical streaks that appear on the image after warm up, and get worse (more streaks) the longer the projector is on. I...
Steve, your issue is not the bulb...
Sounds like you have a problem with either a ribbon cable from your main board to red LCD panel, or a main board failure.
Aug 15, 2010 | Panasonic PT LC75U Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    I can't get any red in my displayed image. I have
    The red lcd has gone bad...change the lcd...and it will work..
    Art
    Jul 29, 2010 | Panasonic PT-LB20U Multimedia Projector
    Just replaced bulb and Lamp red light still comes on when you plug in the Panasonic PT-LB1OU lcd projector. Screen display states: Replace Bulb
    Replace power board: ETXMM519MBGB
    Or replace transistor Q107 on this board with a typical pnp for switching power supllies,there's not a part number for it on the manual.
    Dec 15, 2009 | Panasonic PT-LB10U Multimedia Projector
    Failure to get a trully blank or black screen
    Have never worked on a panasonic projector before I admit, but you get that effect when the 3 LCD panels inside a Sharp (and I assume all brands) LCD are misalligned. To get total black (LCD Projectors find this rather difficult due to the technology) the red , blue and green lcd pixels must be precisely allignend ( they are adjustable by technician and it's a fiddly job) I reckon the green panel is a touch out and it's peeking out between the red and blue squares.
    Dec 12, 2009 | Panasonic ET LA780 Projector Lamp for 780...
    Can't get lens to zoom in and out
    DIRECTLY BEHIND THE FOCUS DIAL IS A SERRATED COLLAR TO ADJUST ZOOM SETTING TURN LEFT AND/OR RIGHT THEN REFOCUS
    Apr 21, 2009 | Panasonic PT LC75U Multimedia Projector
    Projector is showing red as black
    red Lcd panel is failing, your cable is bad, or broken pin on input.
    Oct 23, 2007 | Panasonic PT-LB10VU Multimedia Projector
    Televison & Video Logo
    64 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
