Question about Estate TAWS800JQ Top Load Washer
ESTATE TAWS800JQ1 WILL NOT SPIN
MMY ESTATE TAWS800JQ1 WASHING MACHINE WILL NOT SPIN. IT SEEMS TO AGITATE OK SO I DO NOT THINK IT IS THE GEAR BOX. WE HAVE BEEN HAVING A PROBLEM FOR A WHILE BUT WE WERE ABLE TO HAND SPIN THE DRUM A COUPLE OF TIMES AND THEN IT WOULD SPIN.
  • saike Dec 06, 2007
    I have a kenmore washer that is doing the samething. It gets stuck and will not spin but if I spin it by hand a few times it works fine. I have check the belt and it seems tight. I think it might be the electric motor but would like some advise before I attempt to replace the motor.
  • frog_guy Apr 21, 2009
    Estate washer made it half-way through the spin cycle, then stopped. I've bypassed the lid switch and the motor spins fine. The coupler is not broken. I can turn the other side of the coupler by hand and make the tub spin (though it hits some stiff spots . . . I can generally turn it by hand).
    Clutch?
    I removed the 3 bolts on the agitator (?) below the clutch and now I cannot get it to go back up into place.
    Beyond the "Call someone in" answer, can anyone offer me some advice?
    Sniper:
  • 65 Answers
Both of your problems are the clutch assembly if you are handy you can do this repair
Posted on Feb 18, 2008
2 Suggested Answers
  • 10865 Answers
SOURCE: ESTATE TAWS800JQ1 WILL NOT SPIN
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 27, 2009
I have a Estate Machine. Washer seems to agitate ok but will not spin dry with a full load with out a little help. checked coupling and it is fine.
Some models a few years old had bad bushings in the
super structure post
They scored up the spin tube
Look into a new washer at this point
Jul 04, 2017 | Estate Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
My TAWS800JQ1 washing machine drum seems like it has shifted and is off balance
The bearings are likely shot. But it's possible the spanner nut that holds the basket in place is loose or damaged. Remove the agitator to check spanner nut. Changing bearings is a big job, but if you are handy with tools and good at keeping your cool you can do it yourself.
Jan 06, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
May 27, 2009 | Estate TAWS800JQ Top Load Washer
How can I tell the age of my washing machine?
I would have to say from looking up your owners manual and the copy right date it is about a 2000 model.
Jan 04, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
742 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
