The A/C began smelling like smoke through the ductwork (truck never been smoked in) then after a few weeks the blower stopped. Found 30A fuse blown. Can replace the fuse & it works again but worried about what caused it & what is burning below the surface!
Turned out to be the connector going into what I guess is the temp control module - cooked it pretty good & I need a whole new harness under the dash :(
You may want to change the blower motor as a precaution.
Do all the fan speeds work?
If not .....change the fan resistor board which is right beside the fan at the same time you change the blower fan motor.
