Question about Technics SA-DX850 Receiver
Could anybody tell me what F70 means ?
Hi there ! I'm a customer from Belgium, have been using Technics SA DX850 for like 10 years now and never had any problems till now ... What has been happening in the last two weeks is that the amp suddenly notify a "F70" error on the screen, and all sound stops (except the same "clic" you can year when you turn the amp on).
Then, whatever button I try to turn or push, it only says "Switch Off Power" ...
This F70 error may arrive every two minutes or two hours, unpredictable. I've been checking the air supply, first thought there would not be enough ventilation due to dust, but it all seems ok ...
Could you please help me ? ' can't find this particlualr error reported on the web ... If so, many thanks !!!
Pierre
  • tommycalista Dec 05, 2007
    An add : I've just noticed that the fan isn't working anymore ... Could it be the cause of these spontaneous stops ? The amp is now wide open, so there should be enough air to cool it down, but it still stops after a few minutes ...
  • glennshebang Jan 20, 2008
    I have the exact same problem in the last week with my Technics SA-DX1050 Receiver.  And it's only 6 years old.  I haven't noticed if the fan is working or not since it never stays on long enough (2-5 minutes) before it shuts down and shows the F70 message.  I opened the fan to see if there was dust in there, but no.  I opened the stereo cabinet front and back to create air flow, but it still shuts down.
    The manual for the DX1050 has a troubleshooting section that says if you get the F70 message to turn power off and unplug, then replug and turn on.  This to no avail as well.
  • 979 Answers
You must have air flow through this unit!...accordianman
Posted on Jan 14, 2008
What causes f70 code
This may be blown fuze. This is an informative forum. Read answer one-third down page. Hope this helps Technics stereo receiver F70 error code CK5 Forums
Mar 11, 2015 | Technics SA-DX750 Receiver
Technics sa-dx 950 Intermittent F70 Error
There should be removable access panels under the amplifier IC's that are attached to the heatsink. Remove these panels and inspect the solder connections on the IC's and the voltage regulators that should be mounted next to them. These have always had a tendency to go bad on Technics receivers. If you resolder all of these, you should clear up your problem.
Feb 26, 2015 | Technics Audio Players & Recorders
I have a Technics SA - DX750 Amp Everytime I turn it on I get an error message F70 and then it requests that I turn the power off. This is all it does now, so sound. How do I solve this issue I have...
Hi!
The F70 error certainly indicates a blown fuse inside.
The real problem is why the fuse is blown: there are only two possible reasons
1. there is a short circuit on the output (lines or speakers)
2. you have a blown output transistor (and that means some work and skills to replace).
To be sure, please change the fuse with a same rated fuse (buy more than one because it can blow again). Disconnect the speakers and turn the amp on. If the fuse blows again, it is sure something wrong with the output transistors. If the fuse remains ok, then please check all the wiring to the speakers.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Technics SA-DX950 Receiver
SA-DX750 error F70
I have a technics sa dx 750 receiver that cut...
Dec 21, 2010 | Technics SA-DX750 Receiver
F70 displays after about 5 min of use.
According to Technics reference manual, turn the unit off, unplug for a few, plug in, turn unit on. Consult your "dealer"(authorized repair person, i guess) if light remains on. But doesn't say what f70 means, or associated with.
Unplug and open up the unit, and check the internal fuses on the circuit board. Also check for proper speaker wire hook up. Re-seat the connections. Visibly check the speaker wire runs for shorts, cracked casing, cat/dog chewing. etc.
Hope this helps.
Apr 28, 2010 | Technics SA-DX750 Receiver
F70 on my reciever
Most likley it is in need of repair. I suspect the output IC. Check for bad solder connections on the IC and voltage regulators.
Remove the speakers and see if it still happens (it probably will).
Feb 11, 2009 | Technics SA-DX940
Technics sadx750 and says f70 and turn power off
Feb 27, 2008 | Technics SA-DX750 Receiver
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Oct 30, 2007 | Technics SA-DX750 Receiver
F70 Error on SH-AC300
unit has a blown internal fuse. replace it with exact type of fuse and see what happens. if it blows again, it will need to be returned to a service agent
Sep 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Jun 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX850 Receiver Logo
2,002 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
