Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi ultravision There are green and sometimes red outlines on faces. When I go to the guide (on directv) the words and numbers look like there are another set beside of it which makes it very blurry. Sometimes the faces on the screen looks blurry like another face is projecting out from the original one.
  • 4,402 Answers
Posted on Dec 05, 2007
I have i hitachi ultravision that has a green line and makes double faces
If the convergence is so far out that you cannot adjust with your customer access menu then You will probably need the convergence ICs replaced & possibly a fuse or resistor or 2. Then a complete convergence will be necessary & I HIGHLY recommend having a professional technician perform this task.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
My hitachi 55" ultravision hdtv has a green pear shaped color on the screen, only when it has a dark background, other than that no distortion, no blueing in the corner, no blurriness, nothing. What i
Damaged Optical light engine, this is not the only Hitachi with this problem the ones before the oval was red and was finally settled two years ago in a class action lawsuit.
Dec 15, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
I need to replace the lamp on my projection tv HITACHI ULTRAVISION 53UDX10B. it's difficult to find online. i will need to have the part number for the lamp.
Your model is the DP-15 chassis which is a CRT projection so you do not have a lamp like the DLP models do. You have three CRTs Red, Blue and Green instead of a single lamp.
Jun 09, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I cannot connect my direct tv
The S-Video connections have the same 4 prongs & 1 plastic guide always. You are trying to plug it into a factory-service port on the bottom (looks similar to S-Video, but it's not it). Instead, connect the S-Video wire to Input 3 on the back of the AVC (Audio Video Control Center). The AVC is the box that came with the TV.
Apr 07, 2009 | Hitachi Televison & Video
Red outlines in the picture
somewhere in the tv menu there is a place to make video adjustments. one should be for aligning the color guns. one is for red and the other two are green and blue. it will give you a cross in the center of the screen. it should also give you prompts to adjust the lines for centering and to save changes. this happens eventually on all rear projection tv sets.
May 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No Red in the picture
Could be faulty red socket along w/ ballast. You need tech to see this.
Dec 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 53UDX10B 53" Rear Projection Television Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
