Question about Hitachi 27FX49B 27" TV
Remote codes need code for my hitachi (clu-417u2) tv remote
3 Suggested Answers
  • 6 Answers
SOURCE: Need Program Codes for Hitachi CLU-435U remote
Download this manual:- , it contains all of the codes for your remote.
Posted on Feb 08, 2009
  • 4090 Answers
SOURCE: i have a hitachi tv and need tv code to program a
Try these
Hit achi 0 0 5 6 ,0 1 4 5 ,0 0 1 6 ,0 1 5 1 ,0 0 3 2 ,0 0 3 8 ,
0 2 7 9
Please rate my help++++Thanks for using Fixya
Posted on May 19, 2010
  • 267 Answers
SOURCE: i need the codes for a universal remote control
Posted on May 23, 2010
0 characters
1 Points
Program codes for a hitachi universal remote CLU-4324UG
0281,0294,0223. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 23, 2015 | Toshiba 20AF43 20" TV
Yes, you can know reprogram your 'menu' (and all else...)
If you have this TV(by the by, the 'best' TV ever made:
I've had mine for over ten years: SN: V5F001130
The original 'remote' was CLU-431UG: no longer available,
but you know that....
Here's the solution and very simple:
Radio Shack '5-in-1' catalog# 15-2200 remote.
does it all.
Menu control: (all functions)
Program able for other machines (over 300).
Hope this helps.
on Apr 22, 2008 | Hitachi 35TX20B 35" TV
Remote code needed TV: Hitachi 32ux01s Remote: Sony RM-V220 .....?
My code(s) are: 10156,10030,11145,11156 & 10092. Hope this works for you(:
Feb 12, 2015 | Hitachi 32UX01S TV
What Is the remote code for Hitachi model 31KX8K
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Aug 07, 2014 | Standard (CRT) Televisions
Remote control model, diagram and factory reset
Contact Hitachi directly to obtain a new remote control or search the internet for any of several suppliers of OEM remote controls. A universal remote control may or may not generate the particular code you mention but you can use its code search function to find a code that will work.
Feb 02, 2014 | Hitachi C21 F800S TV
Where can i get a remote for an older hitachi television. i have the model and serial numbers.
EBAY IS YOUR BEST CHOICE, if you have the original remote it has a clu number on it. If the set is over 7 years old the remote is likely not available from Hitachi.
Let me know what you have and I will try to assist.
Sep 24, 2010 | Hitachi Standard (CRT) Televisions
Remote clu-435u Hitachi
The link below contains the original replacement remote control for your unit.
Hitachi 43FDX01B Replacement Remote Control
Sep 08, 2009 | Hitachi 43FDX01B TV
Hitachi C28W440N can't switch over AV channels no remote
have you tried buying a universal remote? you can get a decent one for £10 these days from any electrical store, such as curry's or maplins. it gives you a 3 digit code for the tv to link up with the remote and then you can switch over to av. some hitachi tv's also link up to av automatically if you connect your game station via scart socket (in the back of the tv) if you turn the tv off and link your wii up to the back and make sure the power is turned on before the tv is switched on, there's a chance the tv will auto detect the av channel. not all do but it's worth a try. hope this helps!
Dec 25, 2008 | Symphonic ST419E TV
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Hitachi TV is either 0000 or 0145. If these numbers do not work, then I would buy a newer universal remote. They can purchased at Walmart for less than 10 dollars.
Jul 11, 2008 | Hitachi C25-RF35S 25" TV
Hitachi 27FX49B 27" TV Logo
103 people viewed this question
Top Hitachi Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Standard (CRT) Television Expert? Answer questions, earn points and help others
