Question about Panasonic KX-FL511 Plain Paper Laser Fax
Clear Vertical lines
The documents come through the lines just fine, but there's a vertical line that nothing shows up in. It cuts through numbers and words that I very much need. Help!!!
Thank you!
  • RISTyler Dec 05, 2007
    Well, I don't think I was clear enough and that's my fault! I was typing in a hurry!!!
    The Fax machine is in another branch office . When I recieve the faxes they send, there's the clear vertical line. This only happens when it is from their fax machine. I was wondering if it may have something to do with the scanner in the machine, and if there's a way we could clean it.
    I couldn't find anything on the Panasonic website... uuugh
  • 95 Answers
In a pinch, you can take out the toner cartridge and shake it side to side (gently), then put it back in the machine. This will also help isolate if it is the toner cartridge or not. If it clears up after you do this, you will need to get a new toner cartridge.
Posted on Dec 05, 2007
  • 208 Answers
It sounds like you need a new cartridge. I am not familliare with that product, but I would strongly suspect the drum or toner cartridge. They may be all one.
Often those cartridges are very low on ink and do not display a message to that effect
  • Rick Kasper Dec 07, 2007
    Sounds like the sending fax has a problem with its scaner.
    May be as simple as some white out on the scanner glass.
    Or there are some segments of the scanner not picking up correctly, which would require a sevice call.
    Yeah, I had assumed the way you typed it the first time that you had problems with the faxes printing out on your machine.
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
When i unlock my nokia 5800 xpress music display showing vertical lines
Hello, welcome to Fixya!
The screen of your phone is defective that's why it is showing those vertical lines.
The solution to this problem is screen replacement.
Have the screen replaced and those vertical lines will disappear forever.
I hope the above information is clear.
Nov 07, 2011 | Nokia 5800 XpressMusic Smartphone
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
Vertical lines when using document feeder to scan
you may have dirty glass on scanner or the feeder rollers are dirty or need replacement.
Jun 02, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Vertical lines in scanned documents
Scan glass has muck on it, needs to be perfectly clear, it is just in where you feed originals.
Nov 21, 2007 | HP LaserJet 3050 All-In-One Printer
My phillips ts2746c221 model
If it is a horizontal line is straite or zig zag, if it is straite then problem in your vertical section,please check the supply of vertical section or output ic of vertical, if it is zig zag line then it could be dry solder in the yoke connector or vertical yoke open, please let me know the vertical ic no.
Oct 22, 2007 | Philips 27PT71B 27" TV
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
Panasonic KX-FL511 Plain Paper Laser Fax Logo
81 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
