Question about Microsoft Xbox 360 Console
Xbox 360 3 red lights for xbox 360
  • 53 more comments
  • Anonymous Dec 09, 2007
    there are three red lights flashing and the right top corner isnt ive checked the cables but nothing changed power outlet and still the sam thing
  • denisec111 Jul 20, 2008
    three flashing red lights around power button.
  • kennyb1 Aug 28, 2008
    3 red lights on the front of the xbox. The loading tray will open and close but nothing else happens, the game will not load
  • Anonymous Sep 23, 2008
    3 red
  • summerstar79 Sep 23, 2008
    3 red lights flashing draw opens nothing else working
  • Anonymous Oct 06, 2008
    I found out how to fix this problem from this blog:
    http://xbox3603redlights.wordpress.com/
    It is a GPU error and takes about 30 mins to fix!
    Got it sorted though!
    three red lights
  • Anonymous Oct 07, 2008
    2 red lights sometimes it shows 3 flashing!
    flashing red light
    1 red
  • Anonymous Oct 08, 2008
    3 red lights
    got 1 red light
    I have the same problem with a pre-owned Xbox 360 getting the three flashing red lights. After going round and round with Microsoft Xbox Repair, paying $99, sending my unit in and getting back unrepaired, Xbox Legal Dept. informs me that they will not service an Xbox 360 if you are not the original owner. The warranty does not apply and they will not fix your Xbox 360, even if it is the three flashing red lights. Now I am trying to get my $99 back. It would seem that most customer service reps at Xbox repair do not know about this. If you are not the original owner, you need to find someone else to fix your Xbox 360 or repair it yourself. Good luck.
  • iamrobin Oct 08, 2008
    1 red light
    2 red lights for me!
  • Anonymous Oct 09, 2008
    thanks that worked!
    3 red lights
  • Anonymous Oct 10, 2008
    2 red lights
    3 red
  • Anonymous Oct 11, 2008
    2 red lights
    3 red lights
  • Anonymous Oct 12, 2008
    1 red light
    2 red
  • Anonymous Oct 13, 2008
    me too
    2 red lights
    3 red lights
  • Anonymous Oct 14, 2008
    2 red lights
    1 red light
  • Anonymous Oct 15, 2008
    1 red light blinking.
    red lights appear when I turn on my console
  • Anonymous Nov 22, 2008
    when i turn it on it goes straight to a warrning page an 3 red lights come on on the 360 where the power button is at
  • stanmancg132 Dec 02, 2008
    Three red lights are blinking, what do i do
  • Anonymous Dec 02, 2008
    3 red lights
  • Anonymous Dec 03, 2008
    1 red light
    3 red flashing lights sometimes only 1 on
    red light
  • a_jones08 Dec 03, 2008
    3 red light
  • Anonymous Dec 04, 2008
    freezing up on me!
    1 red light
  • Anonymous Apr 25, 2009
    3 red rings
  • wow cd key May 11, 2010
    Check this link out to solve this problem soon:http://xboxinstructions.blogspot.com/
  • wowgold May 11, 2010
    Here is the solution link check this out and solve this problem very easy, hope its helps, all the best... :)http://bb04bdyba069tkcalgqign2f34.hop.cl...
    If you want to solve this problem then you should have to
    check this LINK.
    I think this is the best solution check this out to Click here
  • justinjhon May 11, 2010
    check this LINK.
    If you want to fix this problem soon then you should have to click on the link below: Solution 3red lights problem
  • sarobes May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com'
  • harry_best4u May 11, 2010
    3 Red lights problem is one of the most common problem of Xbox 360. You will
    have to either get it repaired from Microsoft (in case your Xbox's
    warranty is not expired, but one thing to note is that you will have to
    wait for at least 3-4 weeks to get back your Xbox) or you can Fix your
    Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
  • 13 Answers
I just fixed my Xbox360 3 RROD error by removing the heat sinks and reflowing the solder on both the CPU and GPU by using a heat gun and aluminum foil.
1. Remove the XClips and heatsinks.
2. Get some foil and press it around the GPU and CPU chips. This is to protect other SMT devices from getting blown away when the solder melts. I covered about half the PCB surrounding the chips.
3. Cut out a square hole for the chip you are working on, I used my fingernail. Give about an 1/16 inch gap all around the chip for heat to get under the chip but not on the caps etc on the PC board.
4. Run the heat gun all around the edges of the chip, trying not to overheat the silicon chip itself or the caps and resistors on the chip.
5. While heating the chip, I used a thin piece of solder near the chip to guage when it was hot enough to flow the solder (dont let this piece get onto anything when it melts) move all around the edges, aiming at a 45 degree angle into the chip.
6. Clean off the old heat sink compound off of the chips and heatsink and replace.
7. Reassemble the heatsinks, put the XClips back on (no I did not modify anything).
8, To do a quick test, plug in the power switch PCB, the fans, video and power. See if it works, shut it off as soon as you get the spinning green lights (it will overheat quickly without proper cooling giving the two vertical red light error).
Posted on Oct 24, 2008
    Genius:
  • 1,093 Answers
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Posted on Jan 10, 2010
BEFORE YOU SEND IN YOUR XBOX TO MICROSOFT TRY THIS FIRST!!. rap your xbox in a towel and leave it on for 10 minutes no more no less. after 10 minustes have passed unrap it and turn it on.
Posted on Mar 10, 2009
Send it to microsoft they gave a 3 year extended warranty on the three red lights here is the link below to service your 360.
http://service.xbox.com/servicesignin.aspx
Posted on Jan 20, 2009
    Problem Solver:
  • 18 Answers
3 red lights mean that too much compound is covering the gpu and cpu of the xbox 360, which temporarily disables it. you see when you play, the xbox overheats and melts the compound on the gpu and cpu, which disables it. what you gotta do is open it and clean the gpu and cpu which is under the x clamp and heat sink. then you gotta put silicone heat sink paste on the gpu and cpu. this will allow it to create heat signatures from your gpu to your x clamp and your cpu to your heat sink. this will allow your xbox 360 to run again. only use a little bit of the heat sink paste. is this confusing to you tell me.
Posted on Nov 14, 2008
  • jessy bitwa
    jessy bitwa Nov 15, 2008
    you can obtain the silicone heat sink patse at radioshack for 3.99
I just fixed mine.
It is due to the console overheating.
You need to replace the screws for the heatsink and also include nylon washers.
There is a video on youtube that shows how.
called red ring of death.
cost by microsoft $132 myself $4.20
It is very easy and takes about 40 minutes
here is one link but look at a couple to get it right.
http://www.youtube.com/watch?v=5axYHeG4Xeo&feature=related
Posted on Aug 20, 2008
Exactly-- I purchased off Ebay a year ago, now I am having the infamous "ring of light" problem. I don't really know what to do, and I don't know whom to take it to because of the method of purchase.
Posted on Apr 30, 2008
I got the 3 red lights and i am broke, can someone help me? How do you fix problem?
mY SON IS DEVISTATED. arcadiorodriguez39@yahoo.com
Posted on Nov 10, 2008
The 3 red lights indicate a general hardware fault, This issue has been extended out to a maximum warranty period of 3 years from the date of purchase. This includes consoles which are already out of the first 12 month manufacter's warranty period, Microsoft have agreed to compensate anyone who have had to pay for repairs for this issue in the past. No proof of purchase is nessicary, however Microsoft will require the console's serial number before any repairs can be conducted. If you experience this fault, give the Xbox 360 Technical support line a call and everything can be arranged over the phone, Cost's for shipping and handling, Labour, Parts and technical help is all covered by Microsoft free of charge to YOU!
Hope this helps:)
Posted on Mar 02, 2008
    Scholar:
  • 130 Answers
Send it in to Microsoft. They'll fix it for free. "If a customer has an issue indicated by the three flashing red lights, Microsoft will repair the console free of charge -- including shipping -- for three years from the console’s purchase date."
http://www.xbox.com/en-CA/support/petermooreletter.htm
Posted on Dec 04, 2007
What if you have this problem and they you purchased your system from a dealer off ebay who will not repair you system because thier 30 day warrenty is up?
Posted on Feb 07, 2008
    Problem Solver:
  • 10 Answers
Ok sounds daft but switch on your xbox and wrap it in a few tea towels for a lil bit , overheat it basicly , then try agen .. i dont know why this works it just does lol
Posted on Aug 28, 2008
3 Suggested Answers
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
  • 12 Answers
SOURCE: As playing Xbox 360 system shuts off two red lights occurs.
2 red lights is overheating you can try and leave the console alone and see if that cools it down, sometimes this will work.If it does not you will need to get it fixed and to do this you should use a good Xbox 360 Repair guide or send it in.
Posted on Nov 05, 2011
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
Jan 14, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
Oct 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 repair in mumbai :- 9819767710/9867635653 ?
HELLO ALL GOOD NEWS FRIST TIME IN INDIA
XBOX 360 3 RED LIGHT ? NO PROBLE CALL ME NOW
WE ARE PROFESSIONAL ALL TYPE OF VIDEO GAMES REPAIRING. NOW WE HAVE NEW SOLUTION FOR XBOX 360 3 RED LIGHT FIX. WE CAN FIX 3 RED LIGHT PROBLEM WITH GUARANTIED.
NOW WE CAN PROMISS U FOR YOUR XBOX 360 VERY EASY NEVER BECOME 3 RED LIGHT PROBLEM. NOW WE HAVE VERY GOOD SOLUTION FOR 3 RED LIGHT.
IF YOU WANT BEST SERVICE AND SPECIALIST REPAIRER FOR YOUR ALL TYPE OF VIDEO GAMES.
PLS FEEL FREE CONTACT US
MAHBOOB ALAM & SERAJ AHMAD
MOB : +919867244969
EMAIL : mahboobidrishi@hotmail.com
Website : http://sonyservice.en.china.cn/
Jan 23, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,377 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
