Question about LG Dishwashers
No inflow of water - LG Dishwashers
    President:
  • 744 Answers
Hello, your problem is going to be with the inlet valve. Remove the panel at the front bottom of the dish washer, turn the water and power off. You will see the inlet valve normally on the left side underneath your dishwasher (sometimes on right) connected to the water supply. Remove the water supply hose/pipe and then remove the wire harness from the valve. Now you can remove the valve from the machine. Just inside the inlet there should be a screen...check this for debris. If debris found clean out and reassemble, If no debris replace the valve and then reassemble. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Posted on Aug 26, 2009
SOURCE:
Water inflow
The problem is Water Inlet Valve.. If u replace the valve your problem will solve.. Dont waste your money to any other spares.
Sep 26, 2017 | LG Washing Machines
Dishwaher does not spray water during the wash or rinse cycle
Check m/c water pump. Look for clogged water ways inside the machine wash chamber. Check you water inflow to the machine also.
Apr 06, 2010 | Maytag 24 in. MDB5600A Jetclean II...
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
No water inflow
make sure door is closed...also check water input hose and when u turn on the machine the lights are on telling you machine is ready,,,,,if this does not solve the problem call LG customer help and service
Mar 07, 2009 | LG WM-2277HW Front Load Washer
No water inflow into ice machine after turning off ice maker -
Hi, sounds sticky to me, or it wants the kids back home. But anyway try finding the travel of the tube, could have fallen off on other side, or has blockage since we have so much junk in our water today. Also although your filter is green if its good, I would take it out and clean it, not replace just clean it, and a must fine hose must be a problem, wish I was there ! Frankie!
May 07, 2017 | KitchenAid Superba Architect KSCS25INSS...
Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
Dec 17, 2008 | Bosch SHU3305 Dishwasher
Dishwashers Logo
95 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
