Question about Sylvania CL972B (Black) 19 in. Flat Panel LCD Monitor
Monitor Turns Black - Won't turn back on when moving mouse
My monitor turns off whenever I leave it idle for more than 2 or 3 minutes. But it will not turn back on when I use the keyboard or move the mouse. It will only sometimes turn back on when I either hardboot the computer or unplug the computer entirely.
What's wrong? How can I fix it?
  • 39 Answers
It is probable that the ROM system, called BIOS (Basic Input/Output System), is set to not wake your computer by moving the mouse or pressing a key on the keyboard.
I do not know which BIOS your computer is running so I can only give a general answer.
When your machine is starting up, look for a message that says "Press F2 to enter BIOS" or something like that. Your machine may have a different F key assigned to enter BIOS.
There should be a setting in there that allows you to change the values for waking the monitor. It should say something like "Use keyboard and Mouse to wake up computer", it won't say those exact words, but something like that. If the value is set to disabled, then enable it. Then save your changes and exit (Usually by pressing F10)
Be careful when in BIOS. Changing settings you do not understand can make your computer behave erratically or stop functioning altogether.
Posted on Sep 23, 2017
5 Suggested Answers
Kimi
  • 277 Answers
SOURCE: Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Posted on Nov 20, 2005
  • 22 Answers
SOURCE: GATEWAY FPD1500 MONITOR POWER ON BUTTON TURNS
check when you plug it in all the copper wires are placed correctly and if that dosnt work while it is plugged wiggle it a bit and if that doesnt work wiggle it more
Posted on Jun 14, 2009
SOURCE: 20.1-inch Sylvania SK2000W-B Widescreen LCD
I finally took the monitor apart and found some bad capacitors.. replaced them with new ones and the monitor is working fine.
Posted on Feb 01, 2010
  • 644 Answers
SOURCE: When I power off my LCD Monitor
If this has happened to two monitors on the same computer, then i dont think the problem is with monitors, i think the problem is with the graphics on the computer, i suggest uninstalling the driver for the graphics card in device manager and then restart the pc to see if that makes any difference. The divice manager in in the properties of my computer icon, just right click and choose properties, then device manager.
Posted on Feb 06, 2010
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
My computer works normally but my monitor suddenly turns dark. I try to turn off the power (monitor) and when I turn it on back, it turns to normal. but few minutes later, the problem goes back. This...
Sir,
Does this happen when you leave your computer idle for few minutes? If so,then the Pc is
simply turning off your monitor to save power when you don't use it.And you can turn it back
on simple by hitting keys on your keyboard or moving the mouse to and fro.However if you
would like to disable/change this option the please do the following.
If you are using Win XP,then
1.Click the windows Start button,then click Control Panel,click Performance And Maintanance
and then click Power Options.
From the window that opens,choose the time period after which you would like your monitor to
get into power saving mode (the default is 5 mins) or choose 'Never' from the drop down box
next to where it says 'Turn off monitor'.Then click the apply button and finally the ok button.
If you are using Win 7 or Vitsa,the please follow the following link to learn how to disable this option.
http://www.howtogeek.com/howto/windows-vista/disable-power-management-on-windows-vista/
Oct 27, 2010 | IBM ThinkVision L170 17" LCD Monitor
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
My monitor turns itself on and off with no prompting
Go into the control panel and check the system settings. You might have it set to turn the monitor off after a low number of seconds of use. If you have it set for 30 seconds, if you don't use the keyboard or mouse for 30 seconds, the monitor will shut off. When you start to use it again, it will come back on.
Feb 10, 2009 | IBM POWER SUPPLY 120W 25P4966 Power Supply
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Monitor FP71E turns black
Your monitor rectifier is dead you need change transistors С5707 and check the Capasitor big one!!!!
Nov 29, 2007 | BenQ FP71E 17" LCD Monitor
Monitor turning off
If I understand you problem correctly, your monitor is turning off when it remains idle? Does it come back on when you use the keyboard or move the mouse? If so, then this could just be caused by the computer's power-save settings. This can be adjusted by right clicking on the the desktop and selecting propeties. Go to the screensaver tab and click on the power button. From here, you can either set the "Turn Off Monitor Time" to never, or to a greater period of time.
Oct 16, 2006 | Sylvania CL972B (Black) 19 in. Flat Panel...
Computers & Internet Logo
278 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
