Question about Canon EOS 30D Digital Camera with 18-55mm Lens
Ex & Built-in Flash
Can not get the correct light coverage shoot at the suject from the same distance if there is a object in from of the subject.
    Problem Solver:
  • 17 Answers
You need to do what is called an exposure lock. Aim at the subject, even if it's out of focus and half press your shutter. Then press the * button on the camera (top right) and it will exposure lock. You can then re-focus, but it will hold the exposure that was metered previously, so you'll get focus on a different object to what the camera has focused on. You can exposure lock anywhere, it doesn't even have to be your subject, it could be a nearby window to underexpose, or a nearby dark area to underexpose. Once you've locked the exposure you can focus somewhere else.
Posted on Feb 07, 2008
Polaroid i835 picture blurry in viewfinder and resulting picture
  1. Slow Shutter Speed
    • Always shoot with plenty of light
    • Shoot with flash (and ensure subject is close enough for the flash to illuminate them!)
    • Use a tripod
  2. Unfocused
    • Ensure subject is at least as far away as the minimum focus distance for your camera - 3 feet is a good rule of thumb for most Polaroid cameras
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 28, 2018 | Polaroid Cameras
Picture blurry in view finder
    • Use a tripod
  2. Unfocused
    • Ensure subject is at least as far away as the minimum focus distance for your camera - 3 feet is a good rule of thumb for many cameras
Mar 28, 2018 | Cameras
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
Every picture has red eye
That's because of the flash position being so close to the center of the lens. You are not alone with this problem as pretty well every point and shoot camera will suffer some type of flash red eye.
Some of the upper level pint and shoot have a red eye reduction mode that can be used check your manual. What this does is sends out a high intensity light so your subject's pupils will close down then the pictures is made. Others will have a red eye correction function built into the camera. If you have Photoshop I believe under tools there is a red eye correction tool. I'm using Photoshop CS4 and it's in that and I believe it's on PS 7 and PS 5 I'm not sure if Elements has it or not.
There isn't a whole lot you can do about it due to the location of the flash. The flash needs to be above the center line of the lens by at least 6 inches and even then depending on the subject to camera distance it's possible to get red eye.
Mar 04, 2011 | Kodak EasyShare C330 Digital Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Blurry and out of focus
Hey ammarhazem,
What is most likely the cause of your blurry pictures is that the on camera flash is not powerful enough to provide light coverage to your subject and the movement of your subject is causing the blurry images. Another problem I see is that you are shooting in Program mode, because in program mode you should have no control over the aperture and if your subject is far away and you are using the on camera flash you would want as wide of an aperture as you can get. I would shoot in aperture priority where you can choose the aperture and the camera sets the shutter for you and I would also invest in a more powerful hotshoe mounted flash. In regards to your red eye problem it is probably due to the distance of your subject from the flash also. How red eye reduction works is the flash fires a # of times prior to the exposure to shrink the pupils so the flash doesn't reflect of the subjects retina which produces the red eye problem. A hotshoe mounted flash would also solve this problem because the angle of the flash would not be as parallel to the lens as the on camera flash would be. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Olympus EVOLT E-500 Digital Camera
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Focusing Difficulties
1. Typical problem subjects for autofocus 1) Very low-contrast subjects 2) Overlapping nearby and distant objects 3) Very bright subjects in the center 4) Subjects moving very fast 5) Subjects through glass Focus on an object that is at the same distance as the desired subject, apply Focus Lock, and then recompose the picture. Or set the lens focus mode switch to (or), and focus manually. (Manual focus is only possible with cameras providing this feature.) 2. Attempting to take pictures out of the camera's shooting distance: When taking pictures out of the camera's shooting distance, the subject will be out of focus. The shooting distance differs from each camera model. Please check the specifications of your camera in the instruction manual to determine the shooting distance.
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Canon EOS 30D Digital Camera with 18-55mm Lens Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
